ᐅ Which Ikea Pax doors are particularly durable for frequent use?
Created on: 21 May 2021 09:13
fielben
fielben
21 May 2021 09:13
I would like to ask a detailed question about the Ikea Pax wardrobe system: Which doors in the Ikea Pax series prove to be particularly robust and durable with frequent use? I am especially interested in the type of construction, choice of materials, and hardware used to reliably withstand heavy use over long periods. I am looking for specific experiences, ideally regarding frequent opening and closing in everyday situations, such as in walk-in wardrobes or households with children. Are there doors that have been shown to hold up better than others—especially concerning hinges, panel stability, and potential wear points? I look forward to detailed responses, preferably mentioning specific models and their typical weaknesses or strengths.
praWarre69
21 May 2021 10:47
fielben schrieb:
Which doors in the Ikea Pax wardrobe series prove to be especially sturdy and durable with frequent use?
Hey, that’s a really good question! 😊 From my experience, the doors with solid glass or the solid wood look hold up best. I have the ones with glass fronts (not the thin single-pane glass, but the reinforced type) in my family home for over 3 years of purely private use – they’re very sturdy and the fittings are strong brass, with hardly any play.
The hinges on the standard wood doors can become a bit loose over time, especially with frequent opening, but they’re easy to tighten again. Sliding doors, on the other hand, look nice but aren’t necessarily more durable; I’ve had the runners wear out after heavy use.
My tip: It’s better to spend a bit more on the doors and make sure they have metal fittings – that really makes a difference. The cheaper particleboard fronts are lighter but don’t last as long with constant use.
karlau
21 May 2021 12:29
praWarre69 schrieb:
The hinges on standard wooden doors can become a bit loose over time, especially with frequent use
I have to disagree here. In my experience, the soft-close damped hinges from Pax are quite sturdy—provided they are used properly and not slammed repeatedly. The problem often lies more with installation or insufficient maintenance; doors can creak or rub if the frame has warped even slightly.
fielben schrieb:
Which doors from the Ikea Pax wardrobe series prove to be especially robust and durable under frequent use?
Generally, I consider the idea that sliding doors last longer to be a myth. Especially with dust buildup and irregular maintenance, the tracks tend to wear out quickly. For hinged doors with glass, proven hardware is reliable. However, for maximum durability, one should consider upgrading to stronger hinges or even professional fittings.
LUISABEL
22 May 2021 08:51
fielben schrieb:
I am looking for specific experiences, ideally also regarding frequent opening and closing in everyday use
The durability of Ikea Pax doors mainly depends on two factors: the front material and the type of hinges.
- Doors with a solid wood or MDF core have been shown to have better shape stability compared to particleboard or thin chipboard.
- Using soft-close hinges reduces stress on the material and significantly extends the lifespan.
Recommendation: The "Voxtorp" doors, featuring a smooth front and MDF core combined with the standard soft-close hinges, offer a good balance between stability and everyday practicality.
Sliding doors are harder to assess depending on usage because the sliding rails experience more wear after frequent use. Regular maintenance (cleaning, lubrication) is essential here.
Compared to other options, thicker, solid doors are clearly advantageous for heavy use.
chenValeri
22 May 2021 17:42
For frequent use, I recommend solid wood fronts. They are more durable and have a more elegant appearance. Soft-close hinges extend the lifespan. Sliding doors are more delicate, especially when dust accumulates in the tracks.
Tevin
23 May 2021 08:03
karlau schrieb:
However, if maximum durability is desired, one should consider upgrading with stronger hinges or even professional fittings.
That’s a good point, and I’d like to add: besides the material and product line, proper installation is also crucial. At Ikea, the mounting hardware is often quite minimal, which can lead to quick wear and tear under heavy use.
- When purchasing Pax doors, it’s essential to ensure the hinges are properly adjusted, not just loosely screwed in.
- The choice of door type also matters: doors with thicker MDF cores and metal fittings are more durable than the cheaper versions made with particleboard.
Regular maintenance and readjustment also help to keep the doors in good condition for a long time. Especially in homes with children or frequent use, investing in higher-quality doors and fittings pays off.
