ᐅ Which IKEA Metod models are particularly suitable for DIY projects?
Created on: 10 May 2017 19:37
ne-jesus
ne-jesus
10 May 2017 19:37
Hello everyone, I am currently looking into IKEA Metod and DIY projects in the furniture area. Specifically, I am interested in which IKEA Metod models are particularly suitable for DIY projects where you want to customize, modify, or even completely redesign furniture. Not just simple assembly, but also expanding it with additional features, surface treatments, or integrated elements. I look forward to your experiences and recommendations, including any tips on specific product variants that work especially well for this.
JAMESON
10 May 2017 20:03
For DIY projects, the Metod kitchen base cabinets with snap-fit connections are great because they are easy to disassemble. Especially the 60x60 cm (24x24 inches) and 40x60 cm (16x24 inches) models can be easily modified. For wall cabinets, it is best to use the models without front mounting, as this makes adjustments easier.
TEBILO
11 May 2017 08:47
The question of which IKEA Metod models are best suited for DIY projects is quite complex and largely depends on what exactly you want to modify or redesign. In general, I recommend using the basic kitchen base cabinet modules, as they offer standardized dimensions and a very sturdy construction. The Metod frame structure is excellent for adjustments such as adding extra shelves, reinforcing the side panels, or attaching custom fronts.
JAMESON schrieb:
For DIY projects, the Metod kitchen base cabinets with snap connections are great because they are easy to take apart.
That’s a very good point—the snap connections at the corners also make remodeling easier if you want to make changes later on. For cabinets with toe kicks, I recommend removing them if you plan a near-floor modification, as they can make adjustments more difficult.
If you plan to treat or paint the surfaces, the particleboard doors are better suited due to their smooth finish compared to the melamine side panels. Models with glass fronts can be more complicated if you need to remove or modify the glass. However, this can be avoided by using open frames or completely replacing the fronts.
In summary: the 60 cm (24 inches) and 80 cm (31 inches) base cabinets are very good for beginner DIYers—they offer enough space for technical installations like drawers or pull-outs and provide plenty of room for modifications. If you want to integrate a countertop, make sure the supporting surface is as flush as possible to keep your modification stable.
What sort of DIY project do you have in mind?
FLONE41
11 May 2017 14:56
I think it’s great that such a specific question about IKEA Metod for DIY projects is being asked here – it shows you’re really eager to create something yourself. I know the feeling when starting with a system like this: on one hand, the freedom to design your own setup, but on the other, the uncertainty about whether everything will hold up or how to choose the best model.
TEBILO schrieb:
The 60cm (24 inches) and 80cm (31 inches) base cabinets are very good for beginner DIYers – they offer enough space for technical installations like drawers or pull-outs and provide plenty of room for modifications.
I can only confirm that. I personally started with an 80cm (31 inches) Metod base cabinet and converted it into a small media shelf with hidden cable channels. It was important to me that I could adjust the interior as needed without having to buy everything new. With the smaller models, I often found there wasn’t enough space for my idea.
By the way, I admire anyone who paints or laminates the smooth surfaces – I’m not quite confident enough to try that yet, but maybe your projects will motivate me to give it a go.
Looking forward to more tips and projects from all of you!
tolokau
12 May 2017 09:22
Regarding the topic "Which IKEA Metod models are especially suitable for DIY projects?" I would like to provide a brief overview that might help some with their decision-making:
- Base cabinets 60x60, 80x60 cm (24x24, 31½x24 inches): Very versatile, sturdy construction, ideal for drawers or pull-outs.
- Tall cabinets 60x200 cm (24x79 inches): Well suited for vertical DIY projects, for example, installing custom internal solutions or using as a mobile cart.
- Wall cabinets without fronts or with glass doors: Interesting if you want to create your own fronts.
Tips:
- The side panels are thin, made of about 18 mm (0.7 inch) particle board, so be careful when drilling or screwing to avoid cracking.
- Cam lock fittings are practical, but you should always firmly screw them in when heavy loads are involved.
- Fronts can be easily replaced with custom wooden doors, MDF panels, or even metal fronts.
- Pay attention to using standard dimensions to avoid needing custom-sized spare parts or fronts.
As a general recommendation, when modifying load-bearing elements, use reinforcing angle brackets.
ne-jesus schrieb:
Specifically, I’m interested in which IKEA Metod models are particularly suitable for DIY projects where you want to customize, modify, or completely redesign furniture?
Of course, the topic can be very broad. I would like to know if you are more interested in practical everyday solutions or more elaborate design ideas.
JAMESON
13 May 2017 11:58
A quick additional note: For simple DIY renovations, standard base cabinets without built-in internal drawers are ideal. They provide more space for installing your own drawers or custom features.
