ᐅ Which IKEA Metod kitchen units are best suited for DIY projects?
Created on: 5 Dec 2022 08:17
BEATIX
BEATIX
5 Dec 2022 08:17
I am planning to design and install a new kitchen myself using IKEA Metod modules. I especially want to know which modules from the METOD range are best suited for a DIY project – meaning those that are easy and safe to assemble independently, durable, and flexible enough for adjustments. I am particularly referring to the cabinets, drawer and door types, and possibly modular interior fittings.
Does anyone have experience with which METOD kitchen modules are especially suitable for DIYers without professional carpentry skills? Additionally, I am interested to know if certain module combinations make the DIY process easier or more complicated.
I look forward to detailed advice, including recommendations on materials and tools that work particularly well. Thanks in advance!
BOLUKEO
5 Dec 2022 09:03
I would clearly recommend the basic base cabinets and upper cabinets. They are sturdy, standardized, and can be easily assembled with simple tools. Drawers are a bit more tricky; it’s better to go for soft-close versions, as they are often easier to install. Wall cabinets with doors are generally very beginner-friendly.
CARLA
5 Dec 2022 10:28
In my experience and based on the technical specifications of the METOD series, the 60 cm (24 inch) wide base cabinets with the standard depth of 60 cm (24 inch) are especially suitable for DIY projects. These modules offer a good balance between stability and ease of handling.
BOLUKEO schrieb:
I would definitely recommend the basic base cabinets and wall units.
I would add that drawer fronts with soft-close mechanisms significantly increase durability and usability. For adjusting the wall cabinets, IKEA’s clip systems are helpful as they make assembly easier without depending on tools. The simple shelving elements inside the cabinets are also well suited, especially if you want to keep complexity low.
Gofoman
5 Dec 2022 11:47
I believe you shouldn’t be too cautious: Most IKEA METOD modules are designed for people who don’t have the time or patience for complicated DIY projects. That’s actually the point. If you really want to do DIY, you can even consider custom modifications—such as combining wooden fronts or attaching your own handles.
CARLA schrieb:
The simple shelf units inside the cabinets are also well suited, especially if you want to keep complexity low.
That’s exactly what I disagree with: The shelves are actually a playground for DIY. They are cheap, quickly adjustable, and perfect for individual purposes. Those who think too conventionally take the semi-finished components that IKEA intended. I say the METOD modules can also be exciting for creative upcycling!
NUPIN
5 Dec 2022 15:33
I’m really impressed by the versatility of the METOD series! Especially the drawer units with their internal compartments – super practical for organizing cutlery and kitchen utensils efficiently 😊.
If you’re into DIY, you should definitely check out the accessories at IKEA. They make the building process a lot of fun. I tried a combination of 40cm (16 inches) and 80cm (31 inches) base cabinets myself, and it worked perfectly and looks fantastic!
So, go for it! Building is not as difficult as it seems, and the results are really durable.
Luciandi
6 Dec 2022 08:22
I find the discussion here really helpful, thanks to everyone who is participating in the question.
Sometimes I still feel a bit unsure about how to combine different cabinet heights in a sensible way, for example, without the result looking awkward or causing difficulties during assembly. Does anyone have specific tips on combining tall pantry cabinets with wide base cabinets?
I really like the METOD modules, but for me, the step from planning to assembly is currently quite nerve-wracking. If you have any advice on the best approach to this and how not to lose motivation – I’d love to hear it!
