ᐅ Which IKEA Metod countertops are particularly heat resistant?
Created on: 22 Jul 2021 10:17
Sirepeo
Sirepeo
22 Jul 2021 10:17
I am currently planning to remodel my kitchen using the IKEA Metod system and am facing the challenge of choosing the right countertops. It is especially important to me that the countertops have high heat resistance, as I often work with hot pots and pans.
Therefore, I am interested in knowing: Which IKEA Metod countertops are particularly heat-resistant? Are there models that are better suited than others due to their materials or surface treatments? Maybe someone has practical experience or can recommend which countertops best withstand heavy heat exposure.
Thanks in advance for your insights and tips!
TANBLA
22 Jul 2021 11:03
The heat resistance of Metod panels is generally limited.
The best options for countertops are acacia wood or HPL-laminated panels. However, you should never place hot pots directly on the surface without a protective mat or trivet.
U
usbla
22 Jul 2021 12:27
It should be noted that IKEA generally differentiates between wood/chipboard countertops with laminate surfaces and solid wood options in the Metod range.
HPL surfaces (High-Pressure Laminate) offer some heat resistance up to about 180°C (356°F), but are not permanently fireproof. Wood species like acacia or oak are more durable due to their natural wood structure, but they do not have a special heat-protective layer.
When using hot pots, I still recommend always using a trivet or another barrier, as thermal cracks or discoloration may otherwise occur.
Additionally, direct contact with embers, flames, or excessive steam should be avoided.
retau
22 Jul 2021 12:49
Great topic! Two years ago, I installed an acacia wood butcher block countertop, and I’m really happy with it. 😊
Of course, I always use coasters when the cookware is hot, but the countertop holds up very well to everyday temperatures. It still looks great, and I haven’t had any burn marks or anything like that.
So, just be careful, but with the right surface, like acacia, you’re definitely on the safe side!
BOSULE
22 Jul 2021 14:04
Additionally, I would like to point out that most HPL countertops from IKEA are sufficiently resistant for normal kitchen temperatures.
Manufacturers often specify a maximum heat resistance of 180 degrees Celsius (356 degrees Fahrenheit), which is usually enough for placing hot cookware briefly.
However, damage can occur quickly from repeated or prolonged heat exposure.
Wood countertops, such as those made from acacia, require regular maintenance (oiling) to remain durable and are more heat-resistant than laminated wood-based materials.
In summary: For greater durability and heat protection, acacia is recommended; otherwise, use HPL with caution.
praWarre69
23 Jul 2021 09:12
I would say HPL is like the tough bodyguard of kitchen countertops – it can handle a lot, but if you constantly push it to the limit with high heat, it will eventually reach its breaking point. 😉
Acacia is the charming classic among the countertops: it still looks great after years of use and has survived more than a few heat challenges without a fuss.
Tip: If you really like it hot, you should always use heat-resistant trivets or mats – even the coolest countertops aren’t fireproof!
