ᐅ Which Ikea Komplement accessories are best suited for the Pax wardrobe system?
Created on: 2 Jan 2023 08:32
Lente
Lente
2 Jan 2023 08:32
I’m currently considering which Ikea Komplement accessories work best with the Pax wardrobe system to make the most efficient and flexible use of my closet. The question is a bit complex because I’m thinking about drawers, inserts, hanging rails, and possibly even lighting elements. It’s important to me that the parts are easily combinable, sturdy enough for everyday use, and as modular as possible so I can easily adjust the setup later on.
Are there any recommendations or experiences in this forum regarding which Komplement components are most useful for Pax? Which combinations of drawers, inserts, or baskets have proven especially valuable in practice? And perhaps any tips for the optimal arrangement or other tricks for organizing?
I’m interested in solutions that are both practical and durable. Thanks in advance for your helpful insights.
Nakar33
2 Jan 2023 09:47
Hello Lente,
Regarding your question about which Komplement accessories work best for Pax, I would like to share some details that, in my experience, are essential.
First of all, the drawer inserts are highly recommended and come in various sizes – they help keep smaller items like socks, underwear, or accessories neatly organized. It is important to pay close attention to the internal dimensions to ensure they fit perfectly into the Pax drawers and do not shift.
Then, the clothes rail rods are practically indispensable. You should consider whether it’s worth combining both shorter and longer rods inside to hang, for example, shirts on one side and long coats on the other. A tip: the brackets for the Komplement clothes rails are sturdier than the standard Pax brackets.
If you mean baskets, I definitely recommend the wire baskets with handles that pull out from the front. They are great for jeans or sweaters because you maintain an overview while ensuring proper ventilation.
Regarding lighting: the Komplement LED strips work well, especially when attached inside the wardrobe sides. Just make sure the power supply is neatly concealed and safely installed.
One last piece of advice: before purchasing, carefully plan your interior layout, measure multiple times, and check which Komplement parts are compatible in terms of dimensions – especially with wider Pax units, there can be variations that make installing accessories more difficult.
If you provide more details about what you mainly use your Pax for (everyday clothing, shoes, accessories), I can gladly offer more specific recommendations.
Danial
2 Jan 2023 10:26
I would like to add a critical perspective to the discussion. The Komplement accessories for Pax are undoubtedly practical and modular. However, one should not assume that they are always the most optimal solution.
For example, while the wire baskets are flexible, they are not necessarily the most stable options if you want to store heavy items like shoes or thick winter clothing. In such cases, it might be worth upgrading with custom-made or third-party components.
Caution is also advised with the drawer inserts: the plastic dividers can loosen or break over time if subjected to constant stress. If you need to support heavy loads and require long-lasting durability, only sturdy inserts made of wood or metal will do.
Furthermore, while the Komplement lighting is nice, I consider it more of a marketing gimmick. Without professional installation, many LED strips look untidy and do not last long.
Therefore, I would recommend not relying solely on Ikea Komplement but complementing it yourself if necessary or using other modular systems.
It would be interesting to hear if anyone here has experience with how Komplement accessories hold up in long-term use.
giabau
3 Jan 2023 07:51
Based on the feedback so far, I would like to provide a brief guide to help with choosing the Komplement accessories for Pax:
- Drawer inserts: Use them for small items, making sure to select the right size. You can also integrate sturdier inserts from other sources, but the Komplement models are perfectly matched to Pax.
- Clothes rods: Combine different lengths within the wardrobe. It is important to mount them using the stronger Komplement brackets. A common mistake is using the standard Pax brackets, which are not always the best choice.
- Wire baskets: Great for airy storage, ideal for sweaters and jeans. Due to their design, they are not suitable for very heavy loads.
- Lighting: Komplement LED strips are good if you want subtle illumination. Note: pay attention to power supply and secure wiring to avoid damage to the modules or the wardrobe.
Additionally, a tip for arrangement:
Plan your wardrobe according to the type of clothing and how often you use it. Hanging clothes require different configurations than folded items. It is helpful to place frequently used items in easily accessible areas.
Danial schrieb:
So I would recommend not relying solely on Ikea Komplement, but supplementing with other modular systems if needed.
I partly agree with this. You really need to weigh what is more important: full compatibility or maximum durability and a custom solution. Especially when working with tight budgets or time constraints, Komplement parts are a very practical choice.
If you have any specific questions about installation or material quality, I am happy to help.
