Good morning everyone,
I am currently trying to decide whether to purchase a dresser or a cabinet from the Ikea Brimnes series. It is especially important to me that the piece is as sturdy and durable as possible, as I want to use the furniture heavily and over several years.
My question to the community is: Which Brimnes variants, such as dressers, cabinets, or bed frames, are particularly robust and stable under everyday conditions? Are there differences in build quality between the various models or versions within the series?
I am interested in details about the construction, materials, and experiences with stability in daily use, for example the load capacity of drawers or the stability of the furniture.
I look forward to your assessments and tips, including any advice on common weak points and what to watch out for when buying.
IANFU schrieb:
Which Brimnes variants, such as dressers, cabinets, or bed frames, are particularly durable and sturdy for everyday use? Are there differences in build quality among the various models or options within the series?Great question, because the Brimnes series is really versatile, but not all of them are equally sturdy.
From my experience: The dressers with drawers are fairly well-built, especially if you don’t overload them with weight. The material is basic fiberboard, so be cautious with moisture. The cabinet with doors (for example, the 2-door version) feels noticeably more stable due to its construction with a back panel compared to an open shelf.
I find the models with cable management on the back especially solid, as their back panel also acts as a stabilizer.
A little tip: When assembling, make sure to tighten all screws well and align the back panel properly – that makes a big difference for stability.
So: dresser for everyday clothes and cabinet for heavier items if stability is a priority. And yes, spending a bit more time during assembly is definitely worthwhile! I’d prefer the options with doors and back panels, as they tend to wobble less.
IANFU schrieb:
I'm interested in details about the construction, materials, and experiences with the stability during everyday use, such as the load-bearing capacity of drawers or the stability of the furniture pieces.That's a very detailed question that deserves concrete answers.
The Brimnes series mainly uses particleboard with a laminate coating, which is an affordable solution, but the overall stability depends largely on correct assembly and the load applied. Particleboard is less load-bearing than solid wood and is sensitive to moisture, so exposure to moisture should be avoided.
Regarding construction: the most stable versions have back panels made of hard cardboard, securely fixed with nails. These back panels are crucial for preventing frame twisting, meaning how much the furniture warps.
For drawers: the better variants with metal runners can support higher loads (up to about 15–20 kg (33–44 lbs) per drawer). The runners should be fully installed and adjusted to prevent premature wear.
For very high stability, it is recommended, if possible, to secure the furniture to the wall, which Ikea also advises for Brimnes pieces.
Overall, I would distinguish between versions with and without legs — those with legs can improve stability on uneven floors, while dressers standing directly on the floor tend to be more stable but may slide more easily.
One last point: for beds, it is advisable to use additional center support beams, as the standard Brimnes bed construction is usually sufficient for everyday use but should not be subjected to excessive point loads.
If you have more details about the model (e.g., a dresser with how many drawers), I can provide more precise assessments.
Timofa schrieb:
I find models with cable management at the back especially sturdy, as the back panel also acts as a stabilizer.This is an important point and highlights that the back panel significantly contributes to stability.
In my opinion, it is crucial to pay attention to the back panel mounting in the Brimnes series. When installed correctly, the series is sufficiently stable for normal use. Versions without a back panel or with a lower-quality back panel, such as open shelves without a fixed back, are noticeably less stable.
Additionally, the connection points between the side panels and the top panel in many Brimnes furniture pieces are made using dowels and screws, which greatly affect stability. A solid connection of these joints strongly shapes the user experience.
Conclusion: If possible, choose the version with a full back panel and ensure proper attachment during assembly. This is the most important factor for durability and stability in the Brimnes series. Beds and larger furniture should also be anchored to the wall to increase safety and longevity.
