ᐅ What household methods are suitable for gently cleaning IKEA BESTA furniture?
Created on: 4 Mar 2024 14:37
SujonHello everyone,
I recently purchased some IKEA Besta furniture, and since these pieces have both melamine-coated surfaces and some high-gloss fronts, I am looking for a gentle yet effective way to clean them. I am searching for proven household remedies that do not damage or harm the surfaces but still reliably remove everyday dirt, fingerprints, and light stains.
I want to avoid harsh chemicals or strongly abrasive cleaners. Perhaps there are natural or mild household methods that work well? What are your experiences specifically with Besta furniture, and what mixture or application do you recommend for a thorough but gentle cleaning?
Thank you in advance for your tips!
ju_ren schrieb:
It’s best to use a mixture of lukewarm water and some mild dish soap.That’s generally a safe starting point, but I’d like to elaborate a bit, especially concerning the materials used in IKEA BESTA:
- The melamine coating is durable, but it is not resistant to strong cleaning agents or abrasive additives. Therefore, you should only use very mild cleaners.
- Use lukewarm water, never hot, as heat can affect the adhesive joints on the furniture fronts.
- I recommend using a soft microfiber cloth for cleaning, not only to avoid scratches but also because it is easy to rinse out.
- For tougher stains, you can try a small amount of white vinegar diluted with water (approximately 1:10 ratio). Vinegar is a gentle cleaner that effectively removes grease and fingerprints, but please test it first on an inconspicuous area to check its effect on glossy surfaces.
- Avoid ammonia-based or chlorine-containing cleaners, as these can dull the surface.
Do you have specific stains that are particularly difficult or you’re unsure about? Then I can provide more detailed advice on the appropriate treatment.
Palenar schrieb:
For tougher stains, you can try a small amount of white vinegar diluted with water (approximately 1:10 ratio).I have also successfully used this method, especially for grease stains, which are often very noticeable on high-gloss surfaces. From my experience, it is important to dilute the vinegar well and apply it with only light pressure to avoid damaging the surface.
What I would like to add is that after cleaning with the vinegar solution, you should always wipe again with clean water and dry the surface immediately to prevent water spots.
For routine maintenance, I personally like to use a damp cloth with a little mild dish soap and avoid harsh cleaners completely. For stains that have been there for years, I have occasionally used a diluted gall soap solution—but never stronger than a 1–2% concentration.
