ᐅ Which Heating System Is Suitable for a Garden House (Used as a Home Gym)?
Created on: 14 Aug 2019 20:12
Sven1969
Sven1969
14 Aug 2019 20:12
Dear forum members,
I am currently having a wooden garden shed built in my backyard, where I occasionally want to exercise on my recliner bike. Now the question arises about the right heating solution. The garden shed has a volume of 30 sqm (323 sq ft), with a floor area of about 12 sqm (129 sq ft). It is moderately insulated. Electrical connection is available.
Goal: I want to keep the garden shed at a constant indoor temperature of 5-10 degrees Celsius (41-50 degrees Fahrenheit) during winter. If the temperature drops to -15 degrees Celsius (5 degrees Fahrenheit), frost protection should also be ensured. Wall mounting would be ideal.
What do you suggest I should do? I was thinking of a 1000W infrared heater or an electric convector. Can you recommend a model that you have had good experience with? I have a wide budget regarding price.
Best regards!
KlausiMausi
15 Aug 2019 06:30
Nonsense! Haven’t heard that before.
A cheap blower like that should be enough.
Otherwise, a garden shed—what do you want to use it for in terms of frost protection?
Also, when cycling, you’ll get warm anyway.
Joedreck
15 Aug 2019 11:30
Split air conditioner... Much better than direct electric heating. Also cools at 35°C (95°F).
hampshire
15 Aug 2019 23:14
Infrared heating is great if the garden shed has good insulation. Otherwise, it will be expensive to operate—unless you have a small wind turbine to complement it.
guckuck2
16 Aug 2019 07:57
Simply use a fan heater with frost protection (this can be implemented via a plug-in adapter if necessary) to prevent the place from freezing. When you want to cycle, turn on the heater manually about 5 minutes beforehand. The bike will still be cold, but the surrounding air will warm up quickly as long as there is no strong draft.
A more energy-efficient option would be a heat pump or air conditioner that can also cool. The investment might be around 2000€.
In general, continuously heating a basic wooden structure is energetically inefficient and will result in considerable operating costs.
hampshire
16 Aug 2019 09:45
There are garden houses with proper insulation and “living quality.” In those cases, it’s worth investing in a good heating system. It doesn’t necessarily have to be a simple wooden shed. If it is, then a fan heater solution is probably the most practical.
What kind of garden house is it?
