we are choosing between two prefabricated house suppliers with different heating systems. I’m not very familiar with the topic, so I’m hoping for your opinions.
Basic data: living area of 150 sqm (1615 sq ft) on the ground floor and upper floor, plus 40 sqm (430 sq ft) heated basement.
Option 1: KfW 40 house with Proxon fresh air heat technology – an air-to-air heat pump.
Option 2: KfW 55 house with underfloor heating and Buderus air-to-water heat pump or Viessmann (Vitocal 242-S) air-to-water heat pump.
What do you think about the advantages and disadvantages of these technologies?
Best regards & thanks
boxandroof12 Apr 2019 18:51Separate mechanical ventilation with heat recovery from the heating system.
Try searching for Proxon in the forum here; it was discussed not too long ago.
boxandroof12 Apr 2019 21:54Definitely choose a hydronic heating system and design the heating surfaces for low temperatures (maximum 30°C (86°F) as a target). This is more efficient and cannot be retrofitted later. Anything else leads to dissatisfaction.
Whether an air-to-water heat pump or a ground-source heat pump, both work well if properly planned.
An air heating system can be considered in a passive house.
KfW 40 is quite close to a passive house in terms of heat loss. In that respect, it can definitely work.
Using an air-to-air heat pump for domestic hot water is problematic, as the electricity meter spins quickly during every bath. Blown-in heated air is also not very comfortable. However, it is an inexpensive solution. I would expect this option to be around 10,000€ cheaper.
