ᐅ Which type of heat meter do we need, and what is the approximate cost?
Created on: 20 Sep 2012 05:41
JakobH-1
20 Sep 2012 05:41
Our single-family house has a Viessmann heat pump, model Vitocal 222-G. It is a ground-source heat pump with a capacity of 9.6 kW and a storage volume of 250 L (66 gallons).
To qualify for government subsidies, we now need a heat meter. Does anyone have experience with this and can tell me which type of heat meter we should use and what the device might cost approximately?
Thank you!
MODERATOR
21 Sep 2012 08:55
A heat meter costs about 300€; I cannot recommend any specific manufacturer or model, so it’s best to ask your installer for a recommended device. Check the technical specifications, as the unit might already have a heat meter installed.
gopa_-1
22 Oct 2012 09:32
Hello
For the sizing of the heat meter, you need the nominal flow rate and the minimum-maximum flow rates. This is how the heat meter can be determined.
The price starts at around 350 CHF.
Sandraholster-1
23 Feb 2015 03:32
We have also purchased a heat meter, and ours is from the company Zenner. It cost 280 CHF and we bought it here in Switzerland.
