ᐅ Which types of flooring are ideal for placing IKEA PLATSA furniture?
Created on: 14 Jun 2024 09:17
tason9
tason9
14 Jun 2024 09:17
I am planning to set up my IKEA Platsa furniture in my new apartment and would like to know in advance which types of flooring are best suited for placement. I am especially interested in which floors are ideal in terms of stability, moisture protection, and long-term durability, since Platsa consists of several modules that can be arranged quite flexibly. Are there any recommendations or experiences regarding whether hardwood flooring, laminate, tiles, carpet, or even vinyl floors are better suited?
Additionally, I would like to know if extra measures such as protective mats or underlays are necessary for certain flooring types to prevent damage or slipping.
I look forward to your well-informed opinions and experiences!
klo61
14 Jun 2024 09:45
Hello tason9,
your question about the ideal flooring for IKEA PLATSA furniture is very reasonable, especially since stability and protecting the floor are important factors.
In general, hard and level floors such as parquet or laminate are very suitable. They provide a stable base that prevents the modular furniture from wobbling. It is important that the floor has no unevenness, as otherwise the load will not be distributed evenly.
Tiles are also generally fine, but you should be careful if the furniture might slide, as tiles can be slippery. In that case, non-slip protective mats could be used.
Carpet is less ideal because the soft surface prevents the furniture from standing completely level, and pressure marks can develop over time. Vinyl floors are similarly stable as parquet and laminate; however, with constant weight and movement, surface damage can also occur.
If you set up furniture on sensitive floors, I definitely recommend using felt pads under the feet of the furniture to avoid scratches.
If you have any more questions, just let me know!
Nathanaelk
14 Jun 2024 10:31
Hi tason9,
you’ve already mentioned some important points. Here is a detailed look at different floor types in relation to PLATSA furniture:
- Parquet flooring: The advantage is its natural elasticity. The surface is hard but not as hard as tiles, providing a comfortable feeling of stability and protecting the furniture legs from uneven pressure. However, parquet can be scratched or dented by heavy furniture and point loads. Therefore, a protective mat or felt pads are definitely recommended.
- Laminate: Very durable but also very hard and inflexible. Damage from moving furniture is likely. At the same time, laminate floors are usually very smooth, which makes moving furniture easier. Anti-slip pads or rubber mats help here.
- Tiles: Very durable and resistant to moisture, which can be especially beneficial for kitchens or hallways with PLATSA furniture. However, you should consider the grout height, as uneven areas can make assembly more difficult. Slip resistance should also be taken into account.
- Carpet: Highly uneven, which affects furniture stability. With frequent use, the surface can permanently deform under weight. Additionally, there is a risk that furniture legs sink into the carpet, disrupting balance.
- Vinyl: Very versatile, easy to maintain, and moisture resistant. However, point loads can cause deep pressure marks, so I recommend additional protective measures such as felt or plastic pads.
In summary: as you can see, it’s not just the type of floor, but also the surface condition and the type of load that matter. Which rooms exactly are you planning to furnish? Are there any specific conditions regarding moisture or temperature we should consider?
meGreg
14 Jun 2024 11:07
Good thread, thanks for starting it, tason9!
Personally, I think hardwood flooring is the best match for PLATSA – it’s modern yet classic at the same time. The furniture stands firmly, and the warmth of the wood really creates a cozy atmosphere. If you prefer laminate, be sure to use an anti-slip underlay; otherwise, the units tend to slide across the floor with every movement.
Tiles are, of course, very durable, but to me, they always feel a bit cold and sterile, lacking a homely vibe. However, if practicality is the priority, tiles are a great choice.
Regarding carpet, I would rather advise against it because the furniture tends to sink slightly and then wobble – you only notice this once the units are assembled. Vinyl is kind of an in-between option; it requires a bit of care when it comes to maintenance.
My tip: consider the underlay carefully, as it protects both the floor and the furniture.
I’m curious to see what else will be shared!
te-min
14 Jun 2024 11:25
Parquet or laminate flooring work well, preferably with felt pads on the furniture legs.
Carpet can affect stability.
Tiles are durable; do not forget a non-slip underlay.
V
vin_leo
14 Jun 2024 12:03
Hi everyone,
It sounds like we have a pretty clear consensus here: firm, level floors are preferred! My tip is to make sure the surface is clean and even when installing laminate, and to attach non-slip material to the feet of the PLATSA modules – this prevents annoying shifting.
Also, since it’s important to me: avoid placing furniture directly on old carpet, as it makes every piece unstable.
I’m glad you’re thinking about floor protection as well – a clean floor experiences far fewer dents than you might expect.
