ᐅ Which conduit is suitable for photovoltaic installations?
Created on: 7 Jan 2020 13:41
pffreestylerP
pffreestyler7 Jan 2020 13:41Greetings,
We are hopefully starting the construction of a carport soon. I want to prepare conduit pipes for photovoltaic cables in the gable roof. Which type of conduit pipe do you recommend?
It is called plastic conduit pipe, at least M32. When installing, make sure to avoid 90-degree bends. In visible (roof) areas, use UV-resistant (which is black) material.
pffreestyler8 Jan 2020 09:11Thank you, now I know what I need to get.
hampshire8 Jan 2020 10:42pffreestyler schrieb:
we are hopefully soon starting the construction of a carport. I want to prepare conduit pipes for photovoltaic cables in the pitched roof. Which type of conduit pipe is recommended?It depends on the system and the layout. Wiring requirements can vary quite a bit. Usually, the suggested thin conduit pipes are sufficient. If not, it was a mistake not to research the specifics beforehand.
