ᐅ Which DIY techniques work well to enhance the surfaces of IKEA Hemnes furniture?
Created on: 11 May 2020 09:18
sitelen
sitelen
11 May 2020 09:18
Hello everyone, I want to enhance my IKEA Hemnes furniture, especially the surfaces, and I am looking for proven DIY techniques that work well with the typical Hemnes veneer. I am particularly interested in methods that are durable over time, visually appealing, and require minimal effort in surface preparation. Has anyone had experience with painting, staining, glazing, or applying films? Also, how do these techniques hold up in terms of durability and everyday usability? I would greatly appreciate any tips on materials, necessary preparation (sanding, priming, etc.), and potential pitfalls.
LAURE-TA
11 May 2020 11:03
Hello sitelen, your concern is very understandable, and there are indeed several practical ways to enhance the surfaces of the Hemnes series. First of all: Hemnes usually has a matte lacquer coating, which generally makes sanding and staining more difficult.
Here is my structured recommendation:
- Preparation: Lightly sand the surface to reduce gloss and improve adhesion of paint and stain. Use fine sandpaper (grit 180-220), otherwise you risk damaging the veneer.
- Staining: This is rather uncommon since the lacquer layer prevents absorption. All lacquer residues would have to be removed, which is challenging.
- Paint/Lacquer: High-quality furniture or chalk paint works best. After sanding the surface, apply several thin coats.
- Sealing: Always apply a sealant (e.g., wax or clear lacquer) after drying, otherwise the paint will not last long.
- Alternative foils: Self-adhesive films are a quick solution, but thorough cleaning and degreasing of the surface is essential. Also, durability improves with a primer applied under the foil.
Common mistakes include sanding too aggressively, applying paint too thickly, and neglecting the sealing step. I hope this helps you!
Wyatt
11 May 2020 12:47
I would like to add some more technical details to LAURE-TA. Hemnes furniture is usually veneered with a thin melamine or lacquer layer that serves as protection. Therefore:
- Please sand very carefully to avoid sanding through the veneer. Use sanding mesh or very fine sandpaper (240 grit or finer).
- If you want full coverage, I recommend applying a bonding primer (adhesion primer specially made for smooth surfaces). This greatly helps paint or lacquer to adhere.
- For coloring, chalk paints or acrylic lacquers are well suited, also due to their environmental friendliness and good adhesion.
- If you don’t want a complete overhaul, you can easily work with wax glazes to enhance the grain. However, many skip removing the lacquer layer, and stripping it off is difficult.
- Foils are a quick alternative, but keep in mind that the flexible surface can peel off or crack quickly under heavy use.
A small question: do you want to completely change the original wood tone or just enhance it? That would influence my recommendations further.
sitelen
12 May 2020 07:36
wyatt schrieb:
Quick question: Do you want to completely change the original wood tone or just enhance it? That would affect my recommendations.
Thanks for your input, wyatt. I am mostly interested in a visual change, preferably lighter or pastel-colored finishes. The wood can be somewhat concealed, as the furniture is older and shows some signs of wear. Refreshing the wood look alone is less of my goal.
Durability and effort are important to me, meaning it shouldn’t be too time-consuming or look bad after a short period. I plan to paint doors, drawers, and visible surfaces. I’m open to advice on types of paint and possible sealants.
boelnu
12 May 2020 16:22
Hello sitelen, I understand the feeling of wanting to refresh the Hemnes surfaces, especially when you spend a lot of time with the furniture. A few years ago, I tried repainting the doors of my Hemnes dresser myself.
What helped me:
- First, clean very thoroughly (no greasy residue, otherwise nothing will stick).
- Use very fine sanding, just to dull the surface, do not roughen it with coarse sanding.
- Apply a primer, because otherwise the paint and varnish often peel off.
- I liked chalk paint, especially because it dries quickly and has a matte finish.
- Final waxing with colorless furniture wax protects well against scratches and moisture.
An important tip: Be patient with the layers and apply several thin coats rather than one thick one. At first, I was unsure if it would be worth the effort, but the result exceeded my expectations.
If you like, I can later share some notes on paint types and their durability.
edisondan
13 May 2020 09:08
For additional information: To achieve a secure and durable enhancement of Hemnes surfaces, understanding the material structure is essential.
- Hemnes furniture is mostly made of pine wood with a thin lacquer coating, which should be preserved as much as possible to protect the veneer.
- It is recommended to lightly sand the surface with 220-320 grit sandpaper to slightly dull the smooth finish, improving adhesion.
- Water-based acrylic paints are the best choice for coloring, as they remain flexible and adhere well.
- It is important to seal the surface afterward with matte or satin clear varnish that is UV-stable to prevent discoloration.
- Self-adhesive films offer a short-term solution but are not durable on heavily used surfaces.
- Avoid aggressive stains or solvents to prevent damage to the veneer.
A smooth preparation and the correct sealing are crucial for the result and longevity.
