ᐅ Which DIY projects work well with IKEA HEMNES furniture?
Created on: 22 Sep 2024 18:37
Kaneo38
Kaneo38
22 Sep 2024 18:37
I am considering using some IKEA Hemnes furniture for DIY projects, as this series seems quite sturdy and versatile. I am particularly interested in what types of custom projects are especially well suited for Hemnes pieces.
Which furniture items from the series work best for individual modifications, whether through color changes, alterations, added functions, or even complete repurposing?
Also, I would like to know if anyone has experience combining Hemnes furniture with additional materials (e.g., glass, metal, other types of wood) to create multifunctional furniture or unique design pieces.
In general, it would be great if you could share ideas, examples, or tips on how to really make the most of the Hemnes range without needing to invest in expensive special tools.
I look forward to your suggestions!
blapau
22 Sep 2024 19:04
Hello Kaneo38,
regarding your question: the HEMNES series is indeed very suitable for DIY modifications, mainly because it is made of solid pine – this provides stability and a great surface for refinishing.
- Modifications of HEMNES dressers (e.g., the 8-drawer model) are especially popular, as they can be converted into sideboards or even media cabinets.
- HEMNES beds are also commonly modified by adding drawers or open shelves under the frame.
Regarding materials: glass works wonderfully for surfaces, for example when converting a dresser into a small writing desk. Metal fittings or frames fit well as style elements but require some skill to install.
It is important to always consider load-bearing capacity – for large additions or structures, you should reinforce the furniture. The tools you will typically need include a cordless drill, wood glue, sandpaper, and possibly a router for profiled wood.
I hope this gives you a good starting point.
PeoDaniel
22 Sep 2024 20:19
Hello Kaneo38,
I would like to add a few points to what blapau mentioned. The HEMNES series is not only sturdy but also designed to blend well with various styles.
Based on my experience, the following DIY projects work particularly well:
- Transforming nightstands into mini dressers or even small workstations.
- Converting display cabinets with integrated LED lighting to showcase collectibles.
- Modifying wardrobes by replacing doors with sliding doors or open shelving units.
The surface can be easily customized to suit different interior concepts by staining or painting. For those with basic carpentry skills, it’s even possible to extend the structures using plywood panels and additional wooden strips.
Regarding material combinations: it’s worthwhile to use matte metal or aluminum profiles, as these provide a modern contrast to traditional wood. Glass shelves or doors enhance the elegant appearance and offer functional benefits.
I always recommend taking precise measurements and creating a plan before starting the conversion to avoid wasting materials. If you have any questions about specific handling, feel free to reach out.
Jensson
23 Sep 2024 08:42
to address the original question, here is a brief guide on how to approach DIY projects with HEMNES furniture effectively:
1. Choosing furniture: Dressers, beds, and bookshelves are the most versatile pieces in the series. They can be easily modified by removing components.
2. Planning: Decide whether you want to expand the furniture functionally or customize it visually.
3. Preparing tools: A cordless drill, a jigsaw, sandpaper, and some wood glue are useful. If you want to bevel edges, a router is ideal.
4. Small examples:
- Modify a HEMNES dresser by adding baskets or open compartments for easier access.
- Add casters to the bed base to make the space underneath fully usable.
- Remove the back panel of a bookshelf and replace it with a board painted with chalkboard paint to create a chalkboard wall.
5. Common mistakes to avoid:
- Avoid large modifications without reinforcements, as stability will suffer.
- Inconsistent surface treatments can cause unsightly stains.
Summary: HEMNES furniture is ideal for remodeling when you have a clear plan and follow simple guidelines. Ultimately, this allows you to create a very individual piece with relatively little effort.
RENMA
24 Sep 2024 10:11
To supplement the previous explanations:
The HEMNES series, due to its solid construction, is especially suitable for structural DIY modifications. The wood quality allows for easy drilling, sanding, and painting without loss of quality.
The following points should be considered for DIY projects:
- Material selection: Pine wood is resistant to splintering but relatively soft, so nailing metal fittings works well, although pre-drilling for screws is still necessary.
- Furniture combinations: Joining multiple HEMNES pieces is possible and supported by the standardized dimensions of the series.
- Surface treatment: The original white paint can be lightly sanded with fine sandpaper to apply new colors or stains.
Suitable projects include conversions into multifunctional furniture (for example, a wardrobe with an integrated bench), as well as creating storage space under beds or combining shelving and a workspace in one piece.
In addition to wood and metal, I have had good experiences with integrating plexiglass instead of glass: it is lighter and shatterproof, which increases practicality for everyday use.
Overall, the HEMNES series is excellent for DIY projects due to its modular design, good craftsmanship, and classic style, provided that careful planning is done and structural load capacity is taken into account.
