ᐅ What DIY projects can be done using IKEA BRIMNES furniture?
Created on: 1 Aug 2022 08:27
HeidemarieH
Heidemarie1 Aug 2022 08:27Hello everyone,
I’m currently working on DIY projects involving IKEA furniture, specifically the Brimnes model. I like the simple construction of this piece, and I’m curious about creative and functional modifications or extensions that can be made.
I’m especially interested in ideas on how to effectively and permanently alter BRIMNES components to create additional storage, special multifunctional features, or visual adjustments to better fit one’s living environment.
Are there any projects that go beyond basic repainting or changing handles? Maybe someone with experience in combined furniture arrangements or integrated technical solutions?
I look forward to practical tips, detailed instructions, or even advice on common pitfalls during implementation. Thanks in advance for your detailed contributions!
Hello Heidemarie,
I’m glad to see you are approaching this topic with such thoughtful consideration! The BRIMNES series actually offers many possibilities for DIY projects due to its modular design and clean lines.
Here are a few ideas I’d like to share, including some implementation tips:
- Conversion into a desk or vanity: By placing a tabletop on the dresser and adding cable management openings, you can easily create a workspace. Make sure the connection is stable using brackets or clamps.
- Integrating lighting: LED strips can be easily installed inside, for example within the cabinet or under the shelves, to create accents or make the room appear brighter.
- Cabinet with built-in compartments: Installing additional shelves or small organizer boxes inside the drawers can help optimize storage space.
- Visual customization: Replacing the handles with vintage or industrial styles can significantly change the overall look. Alternatively, you can experiment with adhesive films or spray paints, but make sure to use water-based paints to avoid damaging the surfaces.
Common mistakes often include lack of planning for weight-bearing points and not properly preparing surfaces before painting, which leads to uneven results.
If you need more details on any of these points, I’m happy to help.
Hello Heidemarie,
I would like to add some basic information that may be important for your projects. One aspect often underestimated when working with BRIMNES furniture is the material composition. The furniture is made of particleboard with edge banding. This means that major modifications involving cutting or milling can affect the stability if not done carefully.
I can only confirm that. Additionally, I recommend using fine-grit sandpaper when sanding and sanding all visible edges multiple times after painting so that the transitions look smooth and professional.
One more tip for remodeling: if you plan to install electronics, such as built-in power outlets or USB ports, be sure to include ventilation slots. BRIMNES is not designed for electronics and can overheat.
I hope this helps you.
KUDAISY schrieb:
Typical mistakes often include a lack of planning for load-bearing points and not preparing surfaces properly before painting
To complement the previous explanations, here are some precise practical examples focusing on efficiency and functionality:
- Extension to a media unit: The BRIMNES dresser can be converted into a TV cabinet with concealed cable management by installing cable grommets on the back panel. Be careful not to remove the entire back panel to maintain structural stability.
- Conversion into a bed system: By adding extra slat frame holders and sturdy connectors, BRIMNES bed components can be upgraded to higher storage beds. The load limits of the particleboard panels are critical here, so I recommend using metal brackets at the supporting points.
- Surface treatment: An acrylic-based primer improves the adhesion of paint layers. Always apply paint in thin coats and allow sufficient drying time between each layer.
- Additions with other IKEA elements such as SKUBB boxes or VARIERA inserts offer even more flexibility for storage.
These correspond to the recommended practices for durable and practical DIY projects with BRIMNES.
