ᐅ Which DIY projects are suitable for Ikea HEMNES furniture?
Created on: 6 Feb 2021 09:13
Ixgemar
Hello everyone, I would like to start a discussion to find out which DIY projects work best with Ikea Hemnes furniture. I plan to remodel or functionally expand some of the classic HEMNES cabinets and dressers, but I want to make sure the project is technically feasible and does not damage the furniture or affect its stability. I am particularly interested in creative modifications that are appealing both visually and functionally, for example shelving systems, room dividers, or personalized paint finishes and combinations. Perhaps someone already has experience with such projects or can recommend suitable material combinations, tools, or approaches. What DIY projects have you completed or can recommend with Ikea HEMNES furniture that are both achievable and add significant value? If possible, please also share important details regarding the implementation.
Elijah42
6 Feb 2021 14:08
I would recommend using add-on shelves for DIY modifications instead of completely dismantling the furniture. This way, stability and the original structure are maintained. Simply create extra storage space with shelf inserts or additional boxes.
NIKA61
6 Feb 2021 14:34
An interesting option is converting Hemnes dressers into benches with storage. This works well if you reinforce the top panel and use the drawers as storage space. Simply add wooden battens for reinforcement.
barEsperan
6 Feb 2021 15:10
Various wall shelving systems are also practical, which can be built using HEMNES components with wall brackets. This way, the stability extends from the floor to the wall, and the furniture does not necessarily need additional reinforcement.
Jaime
6 Feb 2021 16:17
Regarding painting, I would like to add that sanding before applying paint is very important to ensure good adhesion. Removing the old surface treatment – usually clear lacquer in Ikea products – is also crucial; otherwise, the new coating will hardly stick.
U
usbla
6 Feb 2021 17:00
The combination of HEMNES shelves with other furniture for room partitioning works particularly well when connected using sturdy metal brackets. This increases safety and prevents the risk of tipping. Especially for larger furniture combinations, decoupling from the floor is advisable to avoid moisture damage.
Ixgemar
7 Feb 2021 08:49
Thank you for the detailed explanations so far. To narrow it down a bit: Does anyone have experience converting HEMNES dressers into work surfaces, for example as a DIY project to create a vanity or home office desk? I’m mainly asking about the required stability and possible reinforcements, as well as what to consider regarding height and legroom.
