ᐅ Which DIY ideas are especially popular with the IKEA Hemnes series?
Created on: 28 Dec 2023 16:37
nickfe
nickfe
28 Dec 2023 16:37
I am currently exploring various DIY ideas, especially related to IKEA furniture. I am particularly interested in the Hemnes model, which attracts many DIY enthusiasts due to its classic, simple design and sturdy construction.
My question to the community is: Which DIY projects are especially popular and practical to carry out with IKEA Hemnes? I am interested in both functional and aesthetic aspects, such as modifications, customizations, or new uses through self-built additions or alterations.
With Hemnes, there seem to be many options, ranging from simple changes like repainting to more extensive modifications that, for example, increase storage space or add new features.
I would like to learn which approaches have proven successful, which materials and tools are commonly used, and what mistakes should be avoided.
Thank you in advance for your experiences and tips!
Nathanaelk
28 Dec 2023 19:12
Hello nickfe,
your question is very well thought out – you already have a good overview of the Hemnes range and its possibilities. I will address this step by step.
Popular modifications include:
- Transforming dressers into sideboards, for example by replacing the doors with glass or cutting them to create open shelves.
- Customizing drawers by installing dividers or special inserts.
- Enhancing the surface by sanding and repainting or applying films and wallpaper to the back panels.
Regarding the modification itself:
The material quality of Hemnes is very good, which allows for careful processing. When sawing or altering the side panels, it is essential to securely fix the cabinet body and use fine saw blades to prevent splintering. Water-based dipping paints are ideal if you want to repaint, as they provide good adhesion after sanding.
Which tools are useful?
- Cordless drill with a fine drill bit for dowels and screws
- Fine saw blade or multi-tool
- Sandpaper, both coarse (80-120 grit) and fine (220 grit)
What should be avoided?
- Rough handling without secure fixing
- Cheap paints with poor adhesion
- Sloppy gluing without appropriate clamps, as parts may shift
Personally, a popular and very practical DIY idea is converting Hemnes nightstands into small rolling cabinets by attaching sturdy casters underneath. This provides flexibility and makes smart use of existing furniture.
I’m interested to know if you already have specific projects planned? That way, I can address potential challenges more precisely.
mabla
29 Dec 2023 08:53
In short: Hemnes is often modified in the following ways:
- Dressers fitted with sliding doors (self-installed)
- Nightstands used as side tables or with pull-out drawers
- Surfaces sanded down and repainted
- Doors replaced with glass
For most people, these are simple, quick modifications that create more storage space or change the appearance.
fredle
29 Dec 2023 14:07
I would like to add a brief guide here that has proven very helpful for anyone wanting to customize their Hemnes dressers or cabinets:
1. Preparation
- Empty the furniture and remove all drawers.
- Clean the surface thoroughly and then lightly sand the paint layer using 180-grit sandpaper – this improves adhesion for paint or vinyl wrap.
2. Modifications
- For planned adjustments such as replacing the doors with glass, it is advisable to buy glazing strips from Ikea or a hardware store and trim them to size if needed.
- For better stability, pre-drill holes before screwing – this prevents splitting.
3. Surface treatment
- For painting, acrylic paint is recommended as it is durable and flexible.
- After the first coat, let it dry well, then lightly sand again with fine sandpaper before applying a second coat.
4. Assembly
- Drawers with dividers can be enhanced with thin wooden strips or felt pads.
- Installing casters? Screw heads must be countersunk and securely fastened to prevent wobbling.
Common mistakes:
- Not allowing enough drying time for the paint.
- Insufficient clamping during cutting, which can damage parts.
- Uneven sanding – it’s better to work in small sections.
With these tips, your DIY modifications should be successful, and the Hemnes furniture will benefit greatly from the changes.
U
usbla
30 Dec 2023 10:22
To complement this, here is a structured overview of the most common DIY ideas for IKEA Hemnes furniture based on experience and feedback from various DIY forums and user groups:
- Color changes: repainting or staining, especially popular for dressers and nightstands.
- Adding glass or plexiglass doors for better visibility and decoration.
- Adding casters or feet to increase flexibility.
- Expanding the interior with custom-cut shelf dividers.
- Combining with lighting (LED strips), especially for display cabinets or shelves.
Materials:
- Water-based paints for easy, low-odor application.
- Wood strips and plywood panels for custom extensions.
- Screws and brackets for extra stability.
Tools:
- Multi-tool (e.g., rotary tool) for precise cutouts.
- Cordless screwdriver and hand drill.
- Sander (optional) to save time.
Avoidances:
- Never use excessive water or solvents on the furniture, as the wood can swell.
- Pay attention to temperature and humidity when painting.
These points are based on common recommendations and have proven reliable in practice.
