ᐅ Which DIY tips are useful for dealing with problems related to Ikea Hemnes doors?
Created on: 2 Jan 2024 14:27
Q
QuintinmarQ
Quintinmar2 Jan 2024 14:27Hello everyone,
I have several Ikea Hemnes cabinets with double doors each, and I’m facing some issues that are really frustrating me. The doors don’t always close flush, sometimes they stick when opening, and especially after changes in load or humidity, the fit is no longer quite right. I suspect that the hinges or the door adjustment aren’t flexible enough, or sometimes wood warping plays a role.
I’m mainly interested in practical DIY hacks or solutions specifically related to the Hemnes model to effectively fix these problems. Things like simple tricks for hinge adjustment, reinforcing materials, small modifications to the door frame, or other methods you can recommend based on your experience.
Does anyone have targeted experience or proven solutions? Suggestions for tools and materials that won’t unnecessarily increase the effort would also be helpful.
Looking forward to your tips!
Hello Quintinmar,
I have several Hemnes cabinets myself and am well familiar with the issue with the doors. A few basic steps usually help without much effort:
- Adjust the hinges correctly: Hemnes hinges generally allow adjustment in three directions (sideways, up/down, in/out). It’s worth taking the time to make small adjustments until the door sits flush.
- Silicone spray or furniture wax can help if the doors stick or scrape. Apply it specifically to the hinges, not on the wood surfaces.
- If the wood warps slightly due to moisture, it can help to leave the doors open at night during high humidity or to use dehumidification.
- If there is rattling, the screws are often loose. Simply tighten them all.
- Adding a plexiglass or foam rubber strip under the door seal can provide a slight fine-tuning effect.
If you like, I can also send you a small guide on adjusting the Hemnes hinges; it’s not that complicated.
If you have any questions, feel free to ask!
I would like to go into more detail on this topic, as the issues with Hemnes doors do have their roots in design and material.
1. Hinge Type and Adjustment
The Hemnes series uses double-adjustable hinges with three adjustment screws. For precise alignment, it is recommended to use a spirit level or angle gauge to ensure the cabinet is not tilted; otherwise, any adjustments will be ineffective.
2. Wood Movement and Environmental Impact
Solid wood is prone to expanding with humidity, especially with doors. One measure is to treat the inside surfaces and edges of the doors with a satin-finish wood oil or varnish to reduce moisture absorption.
3. Reinforcements
If the hinges no longer hold properly, small reinforcement plates can be used to secure the screws better in the wood—very helpful for older doors that have become slightly worn.
4. Cushioning
Another practical tip is to install small silicone bumpers or felt pads at the door contact points. This prevents hard slamming and avoids noise as well as material wear.
Finally, a question: How old are the furniture pieces, and have you already tried a precise adjustment of the hinges?
3. Reinforcements
4. Cushioning
Laukau5 schrieb:
The Hemnes series uses double-adjustable hinges that have three adjustment screws.This is correct and important to emphasize – many underestimate the effect of well-thought-out hinge adjustment.
Laukau5 schrieb:
One measure is to treat the inner sides and edges of the doors with a satin wood protection oil or varnishThis step is often forgotten, although it can actually reduce swelling.
A brief additional tip:
When readjusting the hinges, always work in small increments and frequently check the fit. Large adjustments all at once can make the problem worse.
Therefore, patience is very important.
