ᐅ Which self-built constructions using Ikea PLATSA are especially durable?
Created on: 10 Dec 2019 19:37
EraykenHello everyone,
I am currently focusing intensively on various DIY projects using the Ikea Platsa system. It is especially important to me to find out which of these custom builds stand out for their long-lasting durability and robustness. I am interested not only in the constructions themselves but also in how to best reinforce or enhance the modular system to ensure stability over many years.
Therefore, I would like to know: Which DIY builds with Ikea PLATSA have proven to be particularly durable and stable for you? What additional tips and materials do you use to increase longevity? Are there certain configurations that should generally be avoided because they tend to show weaknesses after some time?
I look forward to your detailed experiences and recommendations!
Erayken schrieb:
Which custom builds using IKEA PLATSA have proven to be particularly durable and stable for you?That’s an interesting question, but to be honest: I would never describe IKEA PLATSA as “durable” if stability is the priority. The system is definitely very flexible, no doubt about that, but for real robustness it almost always requires additional external reinforcements.
In many PLATSA projects I’ve seen, load-bearing capacity is mainly improved by adding extra wood panels or metal brackets – which suggests that the system itself might not be the best foundation for truly long-lasting constructions.
However, if you intentionally combine modules that are mostly wall-mounted and focus on very strong connections, you can achieve something solid. My advice: prioritize proper bracing and, above all, don’t underestimate the flooring of the room where it’s built – uneven surfaces put too much stress on the joints.
KarTristan11 Dec 2019 14:46Gilbert schrieb:
If you specifically combine modules that are designed to be mounted on the wall and pay close attention to strong connections, you can achieve something quite solid.That is exactly what I want to add. For a durable PLATSA construction, wall mounting is a crucial factor. The original fittings from Ikea are sometimes not sufficient, which is why I often use my own metal brackets or heavy-duty anchors.
In addition, I recommend:
- Using medium-density fiberboard (MDF) to reinforce the back panels
- Strengthening connection points with additional screws or brackets
- Distributing loads by adding intermediate shelves that also provide extra stability
About five years ago, I built a large PLATSA shelving unit for storage without attaching it directly to the wall. After a few years, significant weaknesses in stability became apparent. Since then, I only work with wall mounting and extra screws. This way, the self-made unit easily lasts for many years.
I really appreciate how detailed the discussion is so far!
Personally, I have had good experiences with custom-built PLATSA furniture for kids’ rooms, but I made sure that the lower modules have a fully closed front and that the upper parts are securely fixed to the wall. This prevents tipping hazards.
I would also like to add that, especially for frequently used pieces of furniture—such as cabinets or benches—the weight plays an important role. In my experience, strengthening the surfaces with protective film or thin wooden panels helps prevent wear and tear.
Besides screws and brackets, I have successfully used self-adhesive edge protectors that shield the edges from impacts. It may sound trivial, but over time, it really contributes to longevity.
Erayken schrieb:
What additional tricks and materials do you use to improve durability?
Scarlett schrieb:
Besides screws and brackets, I have successfully used self-adhesive edge protection tape to protect the edges from impacts.I agree with that, though I say it with a wink – sometimes our furniture needs a bit of karate training to withstand daily use 😉
For example, I have a PLATSA shelving unit at home that seems quite small, but I reinforced the back panel with a 6mm (1/4 inch) plywood board and added metal brackets on the inside corners.
Sure, it’s not very minimalist, but when it comes to furniture used every day, the extra effort pays off in the long run. Fun fact: my version now feels like it weighs more than I do, but stability is key!
And when it comes to long-term durability, I would personally recommend avoiding overloading shelves whenever possible and instead distributing smaller loads more frequently.
