ᐅ Which combinations of Ikea PLATSA units create the most stable structure?
Created on: 8 Jun 2022 20:37
Lisga
I am currently planning my new wall unit with the Ikea Platsa system and am wondering which combinations of PLATSA modules create the most stable construction overall. I am particularly interested in which combinations of base units, wall-mounted units, and connecting elements are most effective to make the furniture both structurally strong and as torsion-resistant as possible. Are there specific modules or types of connections that are especially suitable for ensuring high stability?
I have already heard that anchoring the unit to the wall is very important, but the choice and arrangement of individual modules also seem to play a major role – for example, whether it is better to combine several smaller modules or use larger units instead.
I would greatly appreciate any experiences or concrete tips, ideally including recommendations on suitable combinations and methods.
BEMAU
9 Jun 2022 13:02
Lisga schrieb:
The depth varies between 40 and 60 cm (16 and 24 inches).
Deeper units (60 cm / 24 inches) tend to warp more under heavy loads, so a stable base plate is important. I always recommend installing an additional horizontal brace or a back panel for this depth.
Also, the wall attachment should be done with strong anchors, especially if the wall is made of drywall.
For load distribution: consistently position heavy items at the bottom and as close to the center of the units as possible.
Jodyro
9 Jun 2022 14:28
As an addition: If you stack multiple modules, you should screw them together at the bottom and then secure everything to the wall to prevent tipping. For increased stability, short cross shelves are also useful.
baupau
10 Jun 2022 09:11
My tip: For Platsa, use the largest modules at the base and smaller ones on top. This way, you achieve a good weight distribution. Also, don’t rely solely on angle brackets; use screws as well in critical areas, especially at the connection points between elements.
Lisga
10 Jun 2022 11:57
Laukau5 schrieb:
The metal angle brackets provided by Ikea are convenient, but they offer limited stability against lateral forces.
semuneo schrieb:
What helped me was consistently using the back panels for reinforcement and adding extra angle brackets in critical areas.
I can already tell that the back panels clearly play a key role here. So to summarize:
- Use sturdy and level base plates
- Utilize back panels to prevent twisting
- Reinforce joints with additional screws
- Secure attachment to the wall with reliable fixings
This is very helpful, thank you all! If anyone has tips regarding the different depths (40cm (16 inches) and 60cm (24 inches)) in terms of stability or resistance to twisting, I would be grateful for further advice.
