ᐅ Which combinations of IKEA PLATSA offer the most storage space?
Created on: 15 Feb 2020 08:17
Ruby40
Ruby40
15 Feb 2020 08:17
I am currently planning my new storage concept using the IKEA Platsa system and am looking for the most efficient combinations that offer the greatest volume. It is important for me to understand how to sensibly combine different widths, heights, and depths to maximize the available space—especially in narrow niches or under sloped ceilings.
I am particularly interested in experiences with smart space utilization options, such as using different module heights or depths within one unit, combinations of drawers, doors, and open compartments, as well as any tips on stability for taller constructions.
Which PLATSA combinations have you used or know of that provide especially large storage capacity? Are there tested solutions for more complex room conditions? I am very much looking forward to your suggestions, including pros and cons of specific setups.
Thank you in advance!
V
vinpau
15 Feb 2020 09:42
Hey Ruby40,
such an exciting topic! I love PLATSA because it’s really flexible, and with clever combinations, you can create a lot of storage space! 😊
For example, I arranged several 60cm (24 inch) wide modules with different heights along a long wall—big drawers for clothes at the bottom and open shelves for boxes at the top. What was really clever: between two tall modules, I built a 30cm (12 inch) deep unit to make perfect use of narrower niches. It provides much more surface area than you’d expect!
Pro tip: Pull the drawers out all the way and you’ll be amazed at how much fits inside. 😄
Looking forward to more ideas here, it’s really motivating!
koduga
15 Feb 2020 11:03
I am currently working on optimizing my PLATSA storage and have realized that combining different depths really makes sense, especially to better utilize room depths that are not completely even.
However, I sometimes find it challenging to combine the right modules so that the result is neither unstable nor visually unbalanced. It helps a lot to plan carefully in detail before purchasing and to make some compromises regarding the dimensions.
I would be interested in hearing about any experiences with stability issues or load-bearing capacity for taller combinations, as I am a bit unsure about stacking the modules.
Thanks in advance!
Laure57
15 Feb 2020 12:28
Hello Ruby40 and everyone interested,
I would like to share some basic tips that can help when assembling PLATSA combinations for maximizing storage space.
- First, it is important to know that PLATSA units come in widths of 60, 80, and 100 cm (24, 31, and 39 inches), depths of 35 and 58 cm (14 and 23 inches), and various heights.
- For optimum use of space, a mix of wider and narrower units often works well to make use of niches or corners in between.
- Drawers usually offer more usable storage than shelves because items can be stacked without slipping. Door units provide more distributed storage space but are better suited for larger items.
- For tall combinations, I definitely recommend using the supplied wall mounting hardware to ensure stability.
- Combining different heights is also ideal: a 60 cm (24 inches) high base unit combined with a 148 cm (58 inches) high upper unit increases storage capacity while taking up little floor space.
If you or others have questions about exact measurements or load capacity, I’m happy to help!
pikin
16 Feb 2020 07:58
Ruby40 schrieb:
I am especially interested in experiences with smart solutions for space optimization, such as using different module heights or depths within a single unit, combinations of drawers, doors, and open compartments, as well as any tips on stability for taller constructions.
For space optimization, a modular design is recommended, where different depths (35cm (14 inches) vs. 58cm (23 inches)) are deliberately combined. This creates a stepped surface that makes use of hard-to-reach areas.
- Combine wide modules (80/100cm (31/39 inches)) with narrower ones (30/40/60cm (12/16/24 inches)) to fill niches.
- For height, a staggered arrangement of low (60cm (24 inches)), medium (128cm (50 inches)), and tall modules (148cm (58 inches)) is effective.
- Drawers maximize storage by providing better space division and visibility.
Stability is ensured by properly using fasteners and braces according to the instructions.
O
onron
16 Feb 2020 11:47
Regarding the stability of tall PLATSA assemblies, I can add: It is essential to secure the individual modules using the included corner connectors and to position the wall anchors appropriately. Only in this way can tall combinations with multiple elements be safe and load-bearing.
Furthermore, deeper modules (58 cm (23 inches)) can be used at the bottom as a base, while shallower modules (35 cm (14 inches) depth) are installed above. This ensures a good weight distribution and more storage space while maintaining an overall stable structure.
For complex room shapes, I recommend measuring on-site and drawing a plan that takes the modules into account to avoid any unused space.
