ᐅ Which combinations of IKEA PLATSA units are particularly stable?
Created on: 11 Mar 2020 14:03
liron
liron
11 Mar 2020 14:03
Hello everyone, I am planning to put together a larger storage solution using IKEA Platsa and want to focus particularly on the stability of the combinations. Since Platsa consists of modular elements, I am concerned that some combinations might be less stable, especially with taller constructions or when connecting multiple modules vertically and horizontally.
I am therefore interested in which combinations of IKEA Platsa modules you consider especially stable and why. Are there specific module sizes, angled connections, or assembly sequences that significantly increase stability? Any advice on proper fastening, material reinforcements, or installation methods would also be helpful.
For example, it would be important for me to know whether a wide base with several lower modules is more effective than a tall tower, or if a combination of closed and open modules plays a role.
I look forward to your experiences and recommendations, as I value a solution that is both aesthetically pleasing and robust.
Laukau5
11 Mar 2020 15:22
The stability of IKEA PLATSA units generally depends on several factors that should be considered during planning. First, it is important to pay attention to the module sizes used and their placement.
- Large, wide modules at the bottom provide a stable base, as they distribute the load.
- It is best to avoid stacking modules too high or to secure them firmly to the wall, as otherwise the units can become unstable and wobble.
- Vertical stacking, meaning several cabinets placed on top of each other, is often less stable than combinations of horizontal rows with cross braces or intermediate shelves.
Regarding connections, it is recommended to use the supplied fasteners and screws, as they are designed to make the individual modules work together reliably under load.
It is also helpful to choose modules with back panels, as these reduce lateral twisting. Open modules without a back panel provide less support.
Additionally, combining modules of different heights and depths can create a staggered arrangement that further reinforces the structure. For example, I placed several shorter modules side by side under a tall module, which virtually prevents tipping.
Another often underestimated factor is uneven floors, which can affect stability. I recommend using adjustable feet or shims to ensure the whole assembly stands level.
How exactly are you planning the overall size and location? That could help tailor the advice more specifically to your situation.
WARREN
11 Mar 2020 15:35
A wide base with multiple modules at the bottom and wall fixation is key for stability. Taller structures must be securely fixed. Pure tower construction without fixation is not recommended.
barda6
11 Mar 2020 16:07
Important: Connect adjacent modules using the connecting pieces from IKEA. This prevents individual modules from wobbling or shifting.
Back panels also significantly strengthen the entire structure. If you need a lot of storage space, combine closed and open modules, but make sure that open modules are stabilized by the adjoining cabinets.
liron
12 Mar 2020 08:19
Laukau5 schrieb:
How exactly are you planning the overall size and location? That might help tailor the advice more precisely to your situation.
Thanks for pointing that out, it’s indeed important: I am planning a combination about 2.2 m (7 ft 3 in) high and 1.5 m (4 ft 11 in) wide, positioned in a corner of my study. There are two walls where I could mount the furniture. The total depth will be around 40 cm (16 in), so fairly slim. I mainly want to create storage space for books and binders.
Aesthetically, I want both open and closed elements. What should I especially consider for corner installation? Is it better to connect modules diagonally or rather classic side by side and stacked?
Also, I wonder if it makes sense to distribute the weight as evenly as possible in such a corner shelf, or if certain cabinets at the bottom should definitely be solid and heavy.
Laukau5
12 Mar 2020 09:44
liron schrieb:
I am planning a combination about 2.2 meters (7 ft 3 in) high and 1.5 meters (5 ft) wide, in a corner of my study. There are two walls there where I could attach the furniture.
This is a good starting point for stability since you can secure the units on two sides. Generally, I recommend the following approach for corner solutions with PLATSA:
- Start with a sturdy base unit on the floor, preferably one with a back panel and a large footprint, for example, an 80 cm (31.5 in) module.
- Build the structure from there in an L-shape along the two walls. Connect all modules not only with the IKEA connectors but also, if possible, use angled metal brackets from a hardware store to increase lateral stability.
- Since you aim for 2.2 meters (7 ft 3 in) height, all units need to be screwed to the wall—this is especially important with PLATSA, as they are not originally designed for very tall assemblies.
- Diagonal connections between modules can improve stability if these joints are secure and load-bearing. Often, however, the IKEA-standard vertical joints combined with wall attachments are sufficient.
- For weight distribution, store heavy items (such as fully loaded binders, books) as close to the floor and inside the closed units as possible. Place open compartments higher up or in the middle to avoid tipping caused by uneven weight distribution.
- Finally, check every step with a spirit level to prevent the furniture from becoming distorted during assembly.
If you want, I can also recommend specific combinations of different module sizes depending on whether you prefer mostly doors or open compartments.
