ᐅ Which paint colors are suitable for painting Ikea Hemnes furniture?
Created on: 5 Sep 2024 14:03
O
onjofa
I am currently planning to paint my Ikea Hemnes furniture and I have a question: Which types of paint are best suited for painting Ikea Hemnes, especially regarding durability, appearance, and application?
I am not looking for a short-term solution, but one that lasts in the long run and also looks good without the furniture becoming cracked or uneven afterward.
Does anyone have experience with specific types of paint (e.g., chalk paint, acrylic, alkyd) or even particular shades that work especially well on Hemnes?
Thanks in advance for the tips!
Regarding the question about intermediate sanding:
A very fine intermediate sanding with sandpaper grit 220 to 320 after the first coat of paint improves the adhesion of the second coat and results in a more even surface.
It is important to sand only lightly so that the paint layer is not damaged but merely roughed up.
On the topic of adhesion primers for foil-faced surfaces:
I recommend special synthetic resin-based adhesion primers that are suitable for challenging surfaces such as melamine, foil, and plastics. These ensure that the paint adheres long-term and does not chip off.
When asked, "Does an adhesion primer on foil really make sense?" my clear answer is yes – without a primer, the paint is unlikely to bond permanently.
onjofa schrieb:
Can you or someone else explain in more detail which bonding primer can be trusted?Sure, onjofa. I recommend, for example, the "Zinsser Bulls Eye 1-2-3" or similar products specifically designed for challenging surfaces. It is easy to apply, dries quickly, and significantly improves the adhesion of the subsequent paint.
Regarding intermediate sanding, I would add that it is essential to remove dust completely before applying the next coat of paint—dust particles can otherwise cause uneven surfaces.
One more tip for application: avoid applying paint too thickly, as this can quickly lead to runs and unsightly finishes. Instead, apply several thin layers one after another.
Brief note on color selection:
- White or cream-colored paints have a timeless appeal
- Dark shades like anthracite create modern accents
- Matte finishes are currently very popular but more sensitive
- Glossy surfaces are more durable and easier to clean
Consider the application area, as this influences the choice.
Good morning everyone,
To explore the topic of colors for Ikea Hemnes a bit further, I would like to add a brief step-by-step guide for optimal preparation and paint selection:
1. Cleaning: Thoroughly remove dust, dirt, and grease from the furniture (e.g., with denatured alcohol or a mild all-purpose cleaner).
2. Sanding: Roughen the matte surface with sandpaper grit 120 to 180.
3. Apply adhesion primer: For foil-coated surfaces, be sure to use a bonding primer.
4. Apply the first coat of paint: Thin and even layers are best; suitable options include acrylic or alkyd enamel paints.
5. Intermediate sanding: Lightly sand with fine sandpaper (220-320 grit) after drying.
6. Apply the second coat of paint: Apply evenly, and pay attention to proper drying times.
7. Optional sealing: If you use a matte paint, be sure to protect it with a clear coat or furniture wax.
An important note: When choosing paint, consider its compatibility with the substrate and the application conditions.
Best regards!
Best regards!
GALEO4 schrieb:
Isn’t the appeal of customizing Ikea furniture exactly about trying something unusual?Of course, having a personal style is appealing, but not everyone has the handyman skills to work flawlessly with black or very dark colors.
Also, keep in mind that dark colors show dust and fingerprints more clearly. So, for furniture that is used frequently, lighter and neutral shades like white, light gray, or off-white beige are more practical.
Don’t get me wrong—I appreciate bold color choices—but everyday usability shouldn’t be overlooked. There is always a compromise between design and function.
To conclude my remarks, here is a tip on color selection:
Pay attention to the finish (matte, satin, glossy). Hemnes furniture benefits from satin or slightly glossy finishes, as these tend to attract less dirt and are easier to clean.
Another small trick: White or light colors make the piece of furniture appear larger and work well with a Scandinavian style. For those who prefer more contrast, using darker colors on drawers or doors can create accents.
I hope these comments help you, onjofa, and everyone else who wants to experiment with Hemnes.
