ᐅ Which colors are suitable for painting IKEA Besta units?
Created on: 20 Oct 2024 18:37
nafolkmar
nafolkmar
20 Oct 2024 18:37
Hello everyone, I am planning to redesign and repaint my existing IKEA Besta shelving system. I have a question: which colors are suitable for painting IKEA Besta to achieve a modern look while also providing a durable, easy-to-clean finish? I assume that besides the color choice, the type of paint also matters (for example, acrylic paint versus spray paint), but my main focus is initially on the color palette. It is also important to me whether there are practical shades that combine style and everyday functionality well for a piece of furniture like Besta—possibly even color combinations or accent colors. I would greatly appreciate tips, personal experiences, or recommendations for specific paints that work particularly well. Thank you in advance!
likuken
20 Oct 2024 21:12
nafolkmar schrieb:
Which colors work well for painting IKEA Besta to create a modern look while also ensuring a durable, easy-to-maintain surface?
First of all: Who really needs all that "modern" stuff? Black, white, or anthracite are timeless choices, of course. But I think the power of bold colors like teal or a rich dark green is often underestimated – especially with Besta, since it tends to look quite simple.
If you’re brave, you can turn the piece into a statement. And maintenance? Matte paint definitely looks great and hides fingerprints better. But in my busy kitchen, I went with a gloss paint because it’s just easier to clean.
So, my advice: Choose colors you like, but make sure to use paint designed for kitchen furniture or surfaces with heavy use – investing in a durable, water-based acrylic paint is worth it. When in doubt, avoid too experimental effects and stick to good-quality solid base colors with character.
Filippo
21 Oct 2024 09:43
likuken schrieb:
Those who dare make the piece of furniture a statement.
This is an interesting approach because the choice of color not only affects the appearance but also significantly influences how well it integrates into the overall room design.
For a practical selection: When painting IKEA Besta furniture, I strongly recommend stripping the surface beforehand or at least sanding the melamine coating. This ensures proper adhesion and durability of the new paint layer.
In terms of color, I suggest neutral tones like white, gray, or even a clean beige if you aim for timeless elegance. Muted pastel accents (such as gray-blue, rose, or sage green) work well to add freshness without being too bold.
From a technical standpoint, I recommend using water-based acrylic paint for interior furniture. It has low odor, good coverage, and is fairly easy to work with. Additionally, its flexibility helps reduce cracking.
If the cabinet will be subjected to heavy use, I advise applying two coats followed by a clear sealant to improve scratch resistance and impact durability.
I’m curious whether you plan to apply the paint yourself or are considering professional help? This can make a difference both in the choice of products and in the color scheme.
dijan
21 Oct 2024 17:26
Filippo schrieb:
For painting IKEA Besta, I strongly recommend stripping the surface first or at least sanding the melamine finish.
Sanding is definitely good advice, otherwise the paint really won’t adhere well! 😅
Regarding color: Personally, I would choose bright but not too bold tones for a light-filled space, such as a creamy yellow or a warm coral. These colors lift the mood without being overwhelming in everyday use.
For those feeling adventurous, dark blue or anthracite works great – it looks very elegant and pairs well with wood or metal accents.
And honestly: many people automatically think of boring white when it comes to IKEA furniture, but with the right color, Besta really gains personality and no longer looks like a standard product.
One more thing: if you want a low-maintenance surface, I’d recommend matte paint, because fingerprints are really annoying and very noticeable on glossy finishes.
What kind of room are you planning to design? That often helps a lot when choosing the color.
