ᐅ Which maintenance products are best suited for Malm surfaces?
Created on: 27 Nov 2021 09:12
eliaske34
I am currently looking into the maintenance of Malm surfaces, specifically Ikea furniture from the Malm series. Since these pieces are usually made of veneer or coated wood, I wonder which care products are truly ideal for preserving the surface in the best possible way.
I am interested in both cleaning and upkeep to prevent the furniture from drying out or getting damaged. Are there certain oils, waxes, or cleaning agents that are recommended? And is it better to use chemical or natural products?
It is particularly important for me to have gentle care that does not affect the grain or leave any unpleasant residues. Who has experience with this and can recommend products or methods?
semuneo
27 Nov 2021 15:42
I can completely understand how confusing this topic can be – I was worried myself some time ago because I was afraid of using the wrong products and damaging my Malm dresser.
What helped me was to be patient and start by trying only mild products. In my case, the dresser with a laminated surface held up well after a few weeks of regular gentle cleaning.
The question of whether to use oil or wax – I get that you want to be sure.
For my veneered furniture, I tried a small bottle of furniture oil, but I was nervous about potential stains. That’s why I tested the oil on a small, inconspicuous area first before applying it more broadly.
Maybe this approach can help you too: try out tips carefully and take your time to evaluate.
All the best for caring for your furniture!
Josan
28 Nov 2021 08:53
Good morning everyone,
I would like to add that for cleaning your Malm surfaces, as Tommy38 suggested, a simple mixture of warm water and a few drops of dish soap works best. It is important to thoroughly wipe the surface afterwards with a dry cloth to prevent moisture from soaking in or causing stains.
For veneer care: if you choose to use oil, it is advisable to apply it sparingly and spread it evenly with a soft cloth. Then allow the surface to dry well and, if necessary, wipe off any excess oil.
Be sure to avoid using silicones or highly glossy polishes – these can quickly make the surface sticky and attract dust.
If you are unsure about which care product to choose, many wood care manufacturers offer high-quality oils, such as Osmo, Rubio Monocoat, or products from Livos. These are specially formulated for wooden furniture.
For foil laminates, as mentioned before, it is generally better to avoid oils or waxes for maintenance.
Good luck with the care!
Renchen
29 Nov 2021 09:37
I would like to add a point regarding long-term care:
Avoiding UV exposure is crucial for Malm dressers, especially those with veneered surfaces, to prevent fading.
Therefore, furniture should not be left in direct sunlight for extended periods. Window films or curtains can help with this.
Additionally, I recommend using coasters, particularly if you place plants or liquids on the furniture, as moisture can penetrate and cause damage.
I would only use care products if it is proven to be real wood, as mentioned several times before. Otherwise, regular gentle cleaning is sufficient.
I hope this complements the previous contributions well.
