ᐅ Which cleaning products are best suited for gently cleaning Ikea BESTA furniture?
Created on: 29 May 2024 08:37
BOONGO
Hello everyone, I have an important question about cleaning Ikea Besta furniture and hope to hear about your experiences: Which cleaning agents are best suited for gently cleaning Ikea BESTA?
Background: The surfaces of the BESTA series are often melamine-coated or lacquered, and I want to avoid using cleaners that could damage, dull, or discolor the surface. I am especially interested in tips on how to remove stubborn dirt without harming the material.
Are there any specific products or home remedies that have proven effective? Or experiences with unsuitable agents that should be avoided? I look forward to your practical advice—preferably with explanations on why certain cleaners are suitable or not.
I also have IKEA Besta, and my biggest concern at first was accidentally damaging the surface. That’s why I tried both mild dish soap and home remedies. I would use vinegar very carefully because I’ve read that it can alter the protective layer.
For stubborn dirt, I sometimes make a paste of baking soda and water, which I then apply very gently and wipe off with a soft cloth. So far, this hasn’t caused any damage, but you really must not scrub!
I think it’s great that alternative cleaning methods are discussed here, as specialized stores don’t always have the right products available.
BOONGO schrieb:
Has anyone had experience using vinegar as a stain remover on melamine-coated surfaces like these?I tried it once on a sticky stain, and it worked really well! But I tested it first on an inconspicuous spot. If you want to avoid any risk, it’s better to use a diluted solution and not let it sit for too long. It’s safer to clean gently and more often than to be too aggressive at once. 😊
Regarding the use of vinegar as a cleaning agent on melamine-coated Ikea BESTA furniture, I would like to add the following:
From a technical perspective, vinegar, due to its acidity (acetic acid, approximately 5%), can potentially damage the surface seal, especially with frequent or prolonged contact. Therefore:
- Always test in a concealed area first.
- Never apply undiluted or allow it to sit on the surface.
- Use a vinegar-water solution only locally on organic stains (e.g., limescale spots, water marks).
For daily cleaning, acidic vinegar water is definitely not recommended.
To better assess the situation: What types of stains or dirt have you encountered most often? This would help provide more specific advice.
