ᐅ Which childproof locks work well for Ikea Besta doors?
Created on: 20 Apr 2022 19:47
FIBEPAU
FIBEPAU
20 Apr 2022 19:47
I am looking for recommendations for childproof locks that work particularly well with the doors of the IKEA Besta system. It is important to me that the locks are sturdy and reliable, while not impacting the appearance of the furniture too much.
Since Besta doors are made from relatively thin material, I also want to avoid mounting holes that are too large or too noticeable. Does anyone know of locking mechanisms that are compatible with these doors, easy to install, and function reliably as childproof solutions in daily use?
Perhaps you have experience with specific models or brands that perform better than the typical clip-on or magnetic locks? I am also interested in installation tips and any potential issues that might arise.
Thanks in advance for all your advice!
Guyju
21 Apr 2022 07:13
Hello FIBEPAU,
Regarding childproof locks for IKEA Besta doors, I have some practical tips that work well and make installation easier:
- Magnetic child safety locks: These are discreet and can be installed inside the door without any visible parts on the outside. It is important to consider the door thickness to ensure the magnet holds firmly.
- Plastic snap locks: These are often mounted with screws or adhesive. For Besta doors, make sure the material is not too thin for screws, otherwise it’s better to use glue or alternative fasteners.
- Latch or lever locks: Usually installed on the inside, these are very secure but somewhat more complex to install.
Common mistakes include:
- Focusing too much on the external appearance of the lock system and neglecting proper fastening.
- Drilling directly into the door material without reinforcement, which can damage or weaken the door.
My advice: Measure the exact dimensions of the doors before purchasing (thickness and material strength) and check whether an adhesive or screw mounting is more suitable.
Which type of lock works best for you also depends on how often the door will be opened. For frequent daily use, a more robust mechanism may be advisable.
I hope this helps!
karlau
21 Apr 2022 22:31
Here is a somewhat provocative perspective on the topic:
Guyju schrieb:
Magnetic child safety locks: These are unobtrusive and can be installed on the inside of the door, so nothing is visible from the outside.
I think this underestimates the need for safety quite a bit. A magnetic lock may be invisible, but how often do we hear that children manage to open them somehow, either by carefully feeling around or using a strong magnet from outside.
In my opinion, safety locks should be robust mechanical devices and not cleverly hidden, but rather clearly represent a barrier.
FIBEPAU schrieb:
Maybe you have experience with certain models or brands that perform better than the classic clip or magnetic locks?
From my experience: The best are these external corner bolts or large sliding locks that are mounted on the inside. While they are visible, they are clear and reliable. Not everyone sees this as a disadvantage—I actually find it reassuring.
Just my opinion, but especially when it comes to children, I wouldn’t cut corners on the safety mechanism!
Deandre
22 Apr 2022 09:58
I understand karlau’s concerns, but for Besta doors, I would still recommend magnetic closures if the installation is done properly.
The doors are often not thick enough for other types of fasteners, and you need to drill very securely to ensure load-bearing capacity.
karlau schrieb:
A magnetic lock may be invisible, but how often do we hear that kids manage to open them anyway
That is partially true, but combined with a second level of child safety or a lock that is easier to access on the wall or elsewhere in the room, magnetic closures work quite well.
Also, there are models with strong magnets and special mechanisms that are really difficult for small children to open. From my experience, the less invasive options are usually better for Besta – you don’t want to damage the doors.
If you choose push locks with screws, make sure to check material reinforcements beforehand, otherwise the locks may become loose after a few weeks.
If you need more information about installation, I’m happy to help.
