we want to install a central ventilation system (mechanical ventilation with heat recovery) and are currently looking into different manufacturers. However, the market is quite confusing, so I am interested in hearing about your experiences with various brands.
I would find app control quite useful. It’s not a must-have, but it would be nice. Ultimately, functionality, ease of cleaning, reliability, and electricity consumption should be the main priorities.
Do you have any tips on what we should definitely pay attention to during installation?
Watcher78 schrieb:
Quick question for those with mechanical ventilation with heat recovery: Where are your supply air and exhaust air ducts located? We have them in the basement, the ground floor in the ceiling, and in the attic, due to the wooden ceiling, in the wall. Is it the same for you?Supply air: Living room/dining room (one room, two ducts), bedroom, hallway, entrance area (all in the floor).
Exhaust air: Upstairs hallway wall, upstairs bathroom wall, guest bathroom ceiling, utility room ceiling, kitchen ceiling.
No basement.
Regards,
Thorsten
World-e schrieb:
Do you have any with moisture recovery, or do you have problems with air that is too dry?No moisture recovery.
Dry air occurs around 30% relative humidity. Sometimes a humidifier is used.
nordanney16 Mar 2016 11:38Watcher78 schrieb:
Quick question for those with controlled residential ventilation systems: where are your supply or exhaust air ducts located? In our case, they are in the basement, and on the ground floor in the ceiling, and in the attic in the walls due to the wooden ceiling. Is it the same for you? Ground floor/upper floor + attic each in the ceilings.
nordanney16 Mar 2016 11:41World-e schrieb:
Do you have any with humidity recovery, or do you have problems with air that is too dry? Without humidity recovery. Problems are very subjective. WE handle the dry air well. Others might have issues with mucous membranes or eyes. So, it doesn’t help you if 95 out of 100 answers say “everything’s fine”; maybe you happen to be among the 5 who have problems.
nordanney schrieb:
So it doesn’t help you if 95 out of 100 replies say “everything’s fine”; maybe you happen to be among the 5 that have problems.Whether it helps me is another matter. However, that doesn’t mean the opinions on this are not interesting. Air that is too dry is also not good for the wood inside the house.
