ᐅ Which maintenance products are suitable for Ikea HEMNES furniture?
Created on: 15 Oct 2020 11:07
fradan
fradan
15 Oct 2020 11:07
I recently purchased some furniture from the Ikea Hemnes series – specifically dressers and nightstands made of solid pine with the well-known white lacquer finish. Now I am looking for suitable care products that gently clean the surface while protecting the wood, without damaging the lacquer or making it look unattractive over time.
I am especially interested in:
- Which cleaning or care products are suitable for the HEMNES series?
- Are there any tips on how to effectively remove discoloration or minor signs of wear?
- Can I use wood care oils or waxes, or are special lacquer care products better?
I would appreciate it if you could share your experiences or recommendations so I can keep the furniture in good condition for the long term.
FLOMARCOS
15 Oct 2020 11:58
For the HEMNES furniture, I recommend mild soapy solutions or special furniture cleaners designed for lacquered surfaces. Do not use oils or waxes, as they penetrate and alter the surface. For minor scratches, special touch-up pens from Ikea or hardware stores are helpful.
Gino38
15 Oct 2020 14:42
The white finish of the HEMNES series is fairly durable, but aggressive cleaners should be avoided as they can cause damage. I recommend:
- A mild all-purpose cleaner or a gentle dish soap solution with warm water
- Wiping afterwards with a soft, damp cloth to remove any soap residue
- Using a special furniture lacquer care stick to protect the surface and refresh the finish
Avoid cleaners containing solvents or abrasive ingredients. Also, when dealing with stains or discolorations, avoid vigorous scrubbing – treat gently instead.
pilous
16 Oct 2020 09:16
fradan schrieb:
Can I use wood care oils or waxes, or are specialized lacquer care products better?
It’s important to make a clear distinction here: the HEMNES furniture is painted (lacquered), not oiled or waxed. Wood care oils or waxes are generally designed for unfinished or natural wood surfaces. Therefore, using them on painted furniture is not ideal—unfortunately, there is a growing misconception that “all” wood care products are universally suitable.
Applying oil or wax on lacquer creates an unattractive, possibly sticky layer that attracts dust and can damage the lacquer over time.
I recommend strictly using products that are explicitly intended for lacquered surfaces. For those seeking a sustainable option, gentle, pH-neutral cleaners are advisable, as Gino38 has already mentioned. This is the only way to ensure the longevity of the white paint finish.
It would also be interesting to hear if anyone has experience with the official Ikea care kit for HEMNES furniture—this would be useful for a systematic comparison.
gadalu
16 Oct 2020 17:33
I would like to add to the previous comments:
- HEMNES furniture is made from painted pine wood, with the clear lacquer coating being especially important for protection.
- According to Ikea, cleaning should be done with soft, slightly damp cloths and mild cleaning agents without solvents.
- Special furniture polish is not necessary since the lacquer provides protection. Excessive oiling or waxing can damage the lacquer layer and cause discoloration.
To remove stains, a mixture of lukewarm soapy water and a microfiber cloth is recommended. Dried-on dirt can be gently treated with a rubber eraser to avoid scratching the surface.
Conclusion: The best care products for the HEMNES series are mild cleaners, soft cloths, and if needed, lacquer repair pens for small scratches. Anything else may damage the lacquer in the long run.
