ᐅ Which maintenance products are suitable for Ikea Hemnes wood?
Created on: 10 Jul 2019 11:23
elbatar
elbatar
10 Jul 2019 11:23
I recently purchased a Hemnes bed along with several other pieces from Ikea’s Hemnes series. Since these are made of solid pine wood and are either untreated or only lightly oiled, I’m wondering which care products or methods are best for maintaining and cleaning this type of wood.
In particular, I’m interested in: Which cleaning agents do not damage the wood? What helps against stains and scratches without harming the surface? Are there specific waxes or oils recommended for Hemnes wood or pine wood? And how often should this care ideally be carried out to preserve the furniture’s lifespan without causing the wood to darken or discolor too much?
I look forward to experiences, tips, and recommendations from this forum—preferably including references to proven products or homemade remedies that have worked well for your Hemnes furniture.
LENNAU
10 Jul 2019 11:52
[@elbatar, post: g5q9i5, member: XXX]
I recently purchased a Hemnes bed along with some other furniture pieces from Ikea’s Hemnes series.
Hello elbatar, regarding your concern: Hemnes wooden furniture is made from solid pine and is often treated with an oil- or wax-based finish that preserves its natural character. For maintenance, it’s important to use mild cleaning products that don’t contain harsh chemicals. Here are a few tips:
- For cleaning, a damp but not too wet cloth is usually sufficient, possibly with a drop of mild dish soap.
- Avoid strong cleaners and abrasive sponges, as they can scratch the surface.
- For stains, a very fine abrasive pad (like steel wool grade 0000) can help, but be careful not to damage the finish.
- For care, you can use specialized furniture oils or hard waxes, such as beeswax products designed for natural wood. Make sure to apply the oil evenly in a thin layer and allow it to absorb well.
- Silicone-based polishes are not recommended for natural wood because they often seal the pores and can eventually cause a blotchy appearance.
- Maintenance intervals depend on use; for Hemnes furniture, I recommend refreshing the finish every 6–12 months, but only as needed.
If you have a light or oiled surface, you can also work with linseed oil or specific pine wood care products. I hope this helps you for now!
nedagla
10 Jul 2019 12:16
Wow, this topic is really fascinating! From my own experience, I use "Osmo Hardwax-Oil" for my Hemnes furniture. The product is excellent because it protects the wood while preserving its natural appearance. Just apply a thin layer and let it absorb – it doesn’t have a strong smell either!
I also recommend removing any dirt immediately, preferably with a soft, slightly damp cloth. For scratches, you can gently sand the area with fine sandpaper and then treat it again with wax.
Considering how much enjoyment and coziness these pieces of furniture bring, it’s definitely worth investing some regular time in their care! 👍
sonplo
11 Jul 2019 09:37
For clarification and additional information: Hemnes furniture is typically made of solid pine wood with a surface treatment that often consists of lacquer or oil-wax blends. This means that not all cleaning products are suitable, especially not aggressive cleaners or pure oils without proper re-fatting.
- Cleaning agents should be pH-neutral.
- For oiled surfaces, common furniture oils or hardwax oils are recommended. These nourish the wood and maintain its breathability.
- For lacquered surfaces, a soft, damp cloth is sufficient for cleaning.
- For stains, it is advisable to use special wood cleaners that are gentle on the surface and do not dry out the wood.
Regular maintenance, meaning cleaning and occasional re-treatment with a wood care product, prevents cracks and yellowing. The optimal care also depends on whether the piece is heavily used or mainly decorative.
elbatar
11 Jul 2019 10:14
LENNAU schrieb:
- For stains, a fine abrasive sponge (very fine, like steel wool grade 0000) can help, but be careful not to damage the surface.
That sounds like a practical approach! Thanks also for the tip about avoiding silicone polish – I had mistakenly assumed that a product from a hardware store contained it.
- For oiled surfaces, regular furniture oils or hardwax oils are recommended.
The information about pH-neutral cleaning products is especially helpful, as I hadn’t paid attention to the pH level when cleaning before.
One more question: Is natural linseed oil really better than industrial furniture care products, or is that more of a myth? I feel like it can sometimes be harder to apply evenly on solid wood furniture. Any tips on that?
praWarre69
11 Jul 2019 14:42
elbatar schrieb:
One more question: Is natural linseed oil really better than commercially produced furniture care products, or is that more of a myth? I feel like it can be harder to apply evenly on solid wood furniture sometimes.
Hey elbatar, great question! It’s better to have a little fun caring for wood than to overthink it for hours 😎
Natural linseed oil is, of course, an organic product and excellent for wood because it penetrates well and protects it from the inside. However, it has the downside of being very viscous, taking a long time to dry, and not all finishes or coatings necessarily respond well to it.
Commercial furniture care products, especially specialized hard wax oils, are much better balanced in terms of protection and appearance and dry faster. By the way, these products usually spread more easily if you apply them with a lint-free cloth and wipe off any excess oil after a short absorption time.
So: natural linseed oil is great, but probably better suited for restorative re-oiling rather than everyday maintenance. 😉
