I recently purchased some furniture pieces from the Billy series with wood surfaces. Now I am wondering: what kind of care is suitable for Billy wood surfaces to preserve the material over time and avoid damage from incorrect cleaning or maintenance? I would like to know exactly which products can be used, whether there are special care products available, and if certain cleaning routines are better than others. Additionally, I am interested in whether different types of wood in the Billy range require different care, or if there are general recommendations that apply to all.
anno58 schrieb:
That is an important point! Avoid using wax and instead keep the furniture dry and clean.I would like to add that this advice applies exclusively to melamine-coated surfaces.
For real wood (veneer or solid wood, which is partly used in BILLY), regular care with wood oil or furniture wax is definitely recommended. It noticeably improves durability and appearance. The challenge is to identify the wood type and adjust the care accordingly.
Summary:
1. For BILLY furniture with melamine resin surfaces, avoid waxes and oils. Use only mild cleaners, no abrasive products.
2. Solid wood veneers should be regularly maintained with suitable wood oils or furniture waxes.
3. Do not leave moisture standing for a long time; dry immediately.
4. Avoid direct sunlight.
5. Regular cleaning reduces dust buildup and preserves the surface.
These are the most important care guidelines – identifying the surface is key.
It is worth paying attention to the manufacturer’s care instructions for BILLY furniture. For example, Ikea provides recommendations for wood and melamine surfaces on its website.
Exactly. From a technical perspective, melamine resin surfaces are very resistant to moisture and do not require waxes. For solid wood, using natural care products is advisable to preserve the microstructure.
Kyler10 schrieb:
Determining the surface is key.
Thanks to everyone for the detailed explanations. I have a quick follow-up question for Victor54: Can you give me tips on how to reliably identify the type of surface? Some BILLY furniture in photos looks similar, but I definitely want to avoid using the wrong maintenance methods. Are there specific tests or typical features that can be easily recognized?
Kladi schrieb:
Can you give me tips on how to reliably identify the type of surface?Yes, I recommend the following approaches:
- Check the surface texture: Melamine coatings are usually very smooth and slightly glossy, while real wood veneers have a natural, slightly irregular grain and often feel warmer to the touch.
- The edge can be a clue: Real wood veneers show the genuine wood cross-section, whereas melamine has a uniform edge.
- A test with a damp cloth (using little water) behaves differently: wood absorbs a small amount, melamine does not.
If the furniture is new, care instructions or material descriptions are often included in the product details or on a label, which can help. If that is not enough, you can always ask the retailer.
I hope this helps.
