I recently purchased some furniture pieces from the Billy series with wood surfaces. Now I am wondering: what kind of care is suitable for Billy wood surfaces to preserve the material over time and avoid damage from incorrect cleaning or maintenance? I would like to know exactly which products can be used, whether there are special care products available, and if certain cleaning routines are better than others. Additionally, I am interested in whether different types of wood in the Billy range require different care, or if there are general recommendations that apply to all.
This is an important question that deserves careful consideration. Fundamentally, BILLY furniture with wooden surfaces involves different materials: real wood veneers, melamine resin coatings, and painted finishes. Therefore, it is not possible to give a general answer about the best care method.
It is essential to identify the surface type before choosing cleaning products. For example, with melamine, aggressive cleaners and waxes should be avoided as they can damage the surface.
Kladi schrieb:
I want to know exactly which products can be used, whether there are special care products available, and if certain cleaning habits are better than others.
Additionally, I would like to add that BILLY furniture with real wood veneers should ideally be maintained using special wax-based furniture care products. These provide protection against moisture and dust.
For painted surfaces, a damp cloth without any chemical additives is sufficient.
Furthermore, direct sunlight should be avoided to prevent fading or warping of the wood.
A few tips for the care and maintenance of BILLY wood surfaces:
- Avoid using harsh solvents and abrasive cleaners, as they can damage the surfaces.
- For melamine finishes, usually just water with a few drops of mild dish soap is sufficient.
- For real wood, special care oils or waxes are recommended to nourish and protect the wood.
- Regular dusting significantly extends the life of the surface.
- Wipe off any moisture immediately to prevent water damage.
Victor54 schrieb:That’s an important point! Avoid wax and instead keep the furniture dry and clean.
For melamine, for example, harsh cleaners and waxes should be avoided
