ᐅ Which cable management solutions work best for IKEA Besta furniture?
Created on: 2 Jan 2018 08:12
Antonpe
Good morning everyone, I am planning to set up my IKEA Besta furniture for my home theater and have been thinking about the best way to manage the cables. The challenge is that Besta units often have limited internal space, and the back panel doesn’t always provide enough room to route cables neatly. Especially with active devices like AV receivers, gaming consoles, and streaming boxes, there are many cables that need to be well organized to prevent strain on the connections and to keep the appearance tidy. I’m interested in which cable management systems or methods work particularly well with the Besta units, especially when assembling or upgrading individual modules. Does anyone have experience with specific clips, channels, straps, or even DIY solutions that can be easily attached to the furniture? Also, how do you handle the often narrow back panel opening to avoid cable clutter? Looking forward to your tips and experiences.
Timofa
2 Jan 2018 12:18
I’d like to share a somewhat simpler method that works well for me: I use flexible cable spirals, which allow you to bundle cables neatly and also make quick changes without everything being rigidly fixed.
I attach the spirals inside on the back using double-sided tape. It might not sound very fancy at first, but it holds very securely and can be removed without leaving any residue if you need to reconfigure.
Honestly, sometimes it’s better not to insist on doing everything strictly by the book with clips and special accessories, but to be pragmatic. This way, you stay flexible and avoid cable clutter on the side.
Kinbu
2 Jan 2018 13:02
I can confirm that neatly grouping cables is very important. For my Besta shelves, I also installed a small plastic cable box for each device, positioned directly under the respective shelf. This way, I only have a few cable pairs running to the back.
For this, I use cable clips from Ikea that are actually designed for other furniture but fit perfectly. There are also flexible cable ducts that can be attached to the inside walls of the Besta units without drilling or screwing.
If someone prefers not to drill, I highly recommend adhesive cable holders, which stick surprisingly well even to smooth surfaces.
NoValentin
3 Jan 2018 07:44
For me, cable ties and adhesive clips are the best choice. They allow you to quickly bundle cables, attach them to walls or the inside of furniture, and adjust them flexibly. Especially important: Do not pull cables too tightly!
mintra
3 Jan 2018 09:16
Antonpe schrieb:
Would you say it’s better to cut off the back panel for improved cable management, or are there already back panel inserts available with cable openings?
To add: In my experience, a modified back panel with precisely placed cutouts significantly improves accessibility and airflow. Installing rubber-grommeted cable glands in the cutouts prevents cable damage. It’s important that the shape of the cutout matches the cable cross-section exactly. Ready-made solutions are rarely found in furniture stores, so DIY or using universal cable glands is usually the best option.
jokau
4 Jan 2018 10:55
I use special flat cable ducts that can be glued to the back of the furniture. This way, cables can be neatly bundled and well protected.
barda6
4 Jan 2018 12:33
mintra schrieb:
It is important that the shape of the recess matches the cable cross-section exactly.
Exactly, openings that are too large cause loose cable bundles, while ones that are too tight can damage the cable. So it’s better to be careful when cutting.
