Hello everyone, I am considering installing a few Billy bookcases from IKEA in my attic apartment. However, I have a problem: the floors here are sloped, and I am wondering which versions or variants of the Billy bookcases should be avoided on sloped floors. Are there specific models that are not suitable due to their design or dimensions because they cause stability issues or simply don’t fit? I imagine some bookcases with fixed shelves or solid side panels might be harder to adapt. I’m curious to hear if anyone has experience or tips on how to best handle sloped floors with Billy bookcases.
fesin30 schrieb:
Are there specific models that are unsuitable due to their construction or dimensions because they cause stability issues or simply do not fit?In general, classic Billy-style bookcases with continuous fixed side panels tend to be problematic on sloped floors, especially if they do not have adjustable feet. I would recommend avoiding models that do not offer options to adjust shelf height or tilt. Also, shelving units on casters or very low-profile shelves with minimal construction height may be less stable on uneven or sloped surfaces.
My advice: choose shelves with adjustable leveling feet or ones that can be leveled through custom modifications (e.g., using wooden strips).
I find this topic really fascinating! 🙂 Sloped ceilings, in particular, offer a great opportunity to get creative. For example, if you use standard Billy-style shelves, they can work on sloped floors, but you might need to do some adjustments. The cool thing is, there are also narrow or extra shallow versions, but I wouldn’t recommend those for sloped areas. They often lack stability and can feel a bit wobbly.
Also: you don’t always have to place a shelf directly on the floor! You can mount it on the wall—then the slope is no longer an issue. This is much more stable and very practical! 🙂
fesin30 schrieb:
I can imagine that some shelves with fixed shelves or fixed side panels are harder to adjust.That’s an important point. I once installed two different Billy bookshelf models on a sloped floor myself, and I can say that especially the classic 80 cm (31.5 inches) wide Billys with fixed shelves and non-adjustable feet pose the biggest challenge. The narrower 40 cm (15.7 inches) variants tend to be more flexible. With a slope, it can help if the back panels are not fully fixed or are modified so the shelf can give a little.
It’s also important how steep the slope is. On very steep floors, every corner of the shelving becomes a wobbly spot. Mounting it to the wall is almost essential if stability matters.
I’m interested in how steep the slope is in your case and whether the floor is only slightly or extremely uneven. Do you have measurements or angles you can share? That helps in giving more specific advice.
FAZAR schrieb:
I’m interested in how steep the slope is on your floor and whether the floor is only slightly or extremely uneven.I agree with that. Often, it really depends on the angle and type of slope whether it’s enough to just mount the shelf on the wall or if the floor needs to be leveled with some type of underlayment.
The weight you plan to store on the shelf is also important. Heavily loaded shelves on significantly sloped floors without adjustable feet can be dangerous.
