I am currently planning to set up a few Billy bookcases from IKEA for my home office and came across the question of which versions of the Billy bookcases have the highest load capacity. Specifically, I am interested in whether certain sizes, materials, or special versions (e.g., with an additional back panel or reinforcement) can carry more weight than the standard models. It would also be helpful to know the realistic maximum load for the individual shelves, especially when storing heavy books or electronic devices.
Does anyone have experience or reliable information on this? Thanks in advance!
LATOLI schrieb:
Which versions of the Billy shelves actually have the highest load capacity?Good question – the Billy shelves are real all-rounders, but if you want to put really heavy loads on them, it’s worth looking at the larger sizes.
From my experience: the standard shelves hold about 30 kg (66 lbs) per shelf according to IKEA, but if you go for the shelves with additional metal reinforcements or even better, the larger models with 80 cm (31.5 inches) width, you can push that up to around 40 kg (88 lbs) per shelf.
Of course, you shouldn’t overdo it, or the shelves will start to sag – especially if the load isn’t evenly distributed.
In short: wider shelves and metal reinforcements are your friends 😎
ritotar schrieb:
According to IKEA, the standard shelves support about 30 kilograms per shelfExactly, IKEA’s specification for the typical Billy shelves is around 30 kilograms per shelf with evenly distributed load.
It’s important to note that there are different versions: the classic Billy features particleboard shelves, which are limited to about 30 kilograms. However, there are also versions with glass shelves, which naturally hold less weight, and versions with reinforced shelves.
If you plan to store heavy items, it’s advisable not to stack the shelves too high, as this can compromise stability.
Additional tip: For higher loads, it’s worth using extra support braces or wall fixings to keep the shelving stable and prevent the shelves from sagging.
LATOLI schrieb:
What is the realistic maximum load capacity for the individual shelves of the Billy bookcases?Regarding load capacity: According to IKEA’s datasheet, the individual Billy shelves made of particleboard have a maximum load of about 30 kg (66 lbs) with an evenly distributed load. This applies to the standard shelves with a depth of 40 cm (16 inches) and a width of 80 cm (31.5 inches). The shelves are approximately 1.8 cm (0.7 inches) thick.
For the 80 cm (31.5 inches) width option, to avoid sagging, it is recommended not to use the full load capacity continuously. For heavier use, retrofit metal reinforcements (available from IKEA or third-party suppliers) can increase the load capacity, sometimes up to 50 kg (110 lbs) per shelf.
With the standard depth of 28 cm (11 inches), the load capacity is somewhat lower, generally around 20–25 kg (44–55 lbs) per shelf.
Additionally, the overall stability of the bookcase depends on wall anchoring. An unsecured bookcase can tip over or become unstable under load, especially with taller models.
My advice: If you want to store heavy books or equipment, choose the 80 cm (31.5 inches) wide bookcase, reinforce the shelves with metal brackets (e.g., L-brackets on the underside), and always secure the bookcase to the wall. This way you combine maximum load capacity and safety.
