ᐅ Which BILLY shelves are suitable for heavy items?
Created on: 26 Dec 2024 09:13
Kueshref
I am planning to use several IKEA Billy bookcases to store heavy items. I have a question: Which Billy bookcases are specifically designed for heavy loads, and how well do the different versions (e.g., width, material, and number of shelves) actually hold up under heavier weight?
I am also interested in whether there are reinforcements or special shelves available in the official range that should be used to ensure the unit is secure. Additionally, it would be helpful to hear about real-world experience regarding the maximum loads that are realistic without the bookcase warping or becoming unstable.
I look forward to a well-informed discussion and thank you in advance for your advice!
Domau0
27 Dec 2024 11:24
Kueshref schrieb:
Is there a way to replace the original BILLY shelves with sturdier custom-made ones?
Definitely yes – many users replace the MDF shelves with solid plywood or solid wood panels at least 18-20 mm (0.7-0.8 inches) thick. It is important to adjust the dimensions precisely and to consider the thickness in relation to the spacing of the side supports to prevent the shelves from sagging too much.
For a width of 40 cm (15.7 inches), sturdier boards are recommended, possibly with a cross brace or additional support to minimize bending. You can also reinforce the back panel (e.g., with a strong MDF board), which significantly improves overall stability.
Also, make sure the shelf components are not exposed to moisture or temperature fluctuations, as this can lead to faster material fatigue.
Kueshref schrieb:
are there differences in the newer BILLY models that maybe use stronger materials?
I’m not sure about this; the BILLY series has only been minimally changed in construction over the decades. Occasionally there are improved connectors, but the basic materials have remained similar. If you want an upgrade, modified shelves are the best option.
Davidleo
27 Dec 2024 12:47
Wow, the tips here are really helpful! 🙂 I have a BILLY shelf that is 40cm (16 inches) wide, and I store heavy binders in it – it has held up without any problems for years! However, wall mounting is really important, otherwise it quickly starts to wobble.
I can only recommend always storing the heavy items at the bottom, as this improves stability. I also use IKEA reinforcement kits for the shelves, which has really increased the load capacity! That’s brilliant! 😉
Looking forward to hearing more of your experiences!
Elijah42
28 Dec 2024 09:18
Davidleo schrieb:
The key point is definitely wall mounting
I agree, wall mounting is essential when dealing with heavy loads. You should also make sure that the shelves don’t sag—thinner MDF boards tend to do that quickly under heavy weight.
If you plan to replace the original shelves, I recommend using at least 18mm (0.7 inch) thick plywood. These shelves have significantly less deflection and are more durable.
Also, regularly check the fastenings, as screws can loosen over time.
If you need more tips on proper installation, feel free to ask!
