Hello everyone, I am planning to use some BILLY shelves from IKEA as room dividers in my apartment to visually separate different zones without blocking too much light or overwhelming the space. My question is: Which BILLY shelves are best suited specifically as room dividers, considering factors like height, width, and stability, as well as the possibility of using both sides (for example, with back panels or open shelves)? Are there any accessories, such as doors or inserts, that work well to make them more effective as room dividers? I would appreciate it if users with experience could share their recommendations or tips on assembly!
I would mainly recommend the tall version of the BILLY shelving unit as a room divider — the 202 cm (79.5 inches) high model. It is not only sturdy but also provides enough surface area to visually separate the space.
You can choose the width according to your needs — the 80 cm (31.5 inches) wide units are good if you want more solid partitions, while the narrower ones (around 40 cm (16 inches)) work better for lighter separations. It is important to secure the shelves with back panels so they can be used from both sides and won’t tip over. The back panel material in BILLY units is usually thin, so if you can replace it, I recommend using a sturdier particle board.
Additionally, it can help to fasten the unit at the top and bottom to the floor and ceiling, especially if it is being used as a freestanding room divider.
FAIKLO schrieb:
Which BILLY shelving units are best suited as room dividers, especially regarding height, width, and stability?
Genevieve25 Oct 2022 11:47I find it interesting that you are approaching the topic of room dividers with BILLY shelves so specifically. However, I would critically question your assumptions regarding stability.
This is basically correct, but the standard back panels are smooth on both sides and usually white, which affects the appearance of a double-sided room divider. An alternative here would be to fit the shelf on both sides with matching wooden back panels or decorative panels to make it more visually appealing and stable.
Furthermore, the dimensions of the shelves can be adapted to your room situation: sometimes it is more elegant to use several low shelves (about 80 cm (31 inches) high) to allow visibility and make the separation feel lighter—especially in smaller rooms.
blapau schrieb:
It is important to secure the shelves with back panels so that they can be used on both sides and do not tip over.
Oh, that’s brilliant! 🙂 I have two BILLY shelves myself used as room dividers in the living room, and I can tell you, the 80 cm (31.5 inches) wide and 202 cm (79.5 inches) tall shelves are just super flexible.
What works really well: using the shelves without a back panel, but filling the shelves on both sides. This way, the space feels open and not too bulky. I also added some small baskets and nice plants. It really looks great and adds life to the partition!
Definitely the version without a back panel is best if you want transparency and airiness. For stability, I fixed small brackets at the bottom to the floor. This way, nothing wobbles and the room divider stands perfectly firm!
Give it a try; it’s a great solution and very reasonably priced! 🙂
FAIKLO schrieb:
Which BILLY shelves are best suited as room dividers, ... possibility to use both sides?
I would like to provide a clear recommendation on how to use BILLY shelves as room dividers effectively:
1. Shelf Selection:
- Height: 106 cm (42 inches) for half-height if natural light is important, otherwise 202 cm (79.5 inches) for more storage and better separation
- Width: 40 cm (16 inches) for narrow room dividers, 80 cm (31.5 inches) for more robust walls
2. Double-Sided Use:
- Standard BILLY shelves with a back panel are only usable from one side
- For room dividers, replace the back panel or cover both sides, for example with thin MDF panels
3. Stabilization:
- Use wall fixings if possible
- For freestanding dividers, ceiling supports or floor brackets are recommended for secure fixing
4. Add-Ons:
- Doors can enhance storage visually and make the front look like a closed surface
- Open shelves on both sides allow for decoration and storage, making the room feel more open
5. Assembly:
- Make sure the shelves are securely connected if using multiple units as a row divider
You can implement this using the following approach:
- Get the basic BILLY shelf without the back panel and thin wooden panels for possible rear covering
- Tools for fixings (brackets, screws, wall anchors)
- Decorative elements for the open sides
This way, you can divide your space effectively while adding practical storage.
I hope this helps!
1. Shelf Selection:
3. Stabilization:
4. Add-Ons:
5. Assembly:
I hope this helps!
