ᐅ Which BILLY shelves are especially sturdy for heavy loads?
Created on: 1 Mar 2023 20:17
POVIN69
Hello everyone, I am facing the challenge of using several Billy shelves from IKEA for heavy-duty storage. I am particularly interested in which models or modifications of the BILLY shelving series have proven to be especially stable and durable. Specifically: which BILLY shelves can withstand high weight loads without the shelves sagging or the entire structure becoming unstable? Are there recommendations regarding shelf size, material thickness, mounting method, or additional reinforcements to optimize load capacity? I look forward to detailed experiences and tips!
POVIN69
2 Mar 2023 10:15
Nathanaelk schrieb:
How precise are your room dimensions? Will the shelf be placed later in a room with masonry walls? Or will it be mounted on a drywall partition?
Thank you, the room has solid brick walls, so masonry, which should be good for wall mounting. The shelves are in the office, which is heated up to 27°C (81°F), so I believe any material deformation due to heat is negligible.
The idea of using additional MDF pads under the shelves and metal braces with angle supports sounds feasible. Does anyone have experience with how much extra weight such reinforcements can realistically support on the shelves?
labar43
2 Mar 2023 13:22
Hey, that sounds great that you have sturdy walls! 🙂 I reinforced a 40 cm (16 inch) deep BILLY shelf myself with a few metal brackets – it has easily held several heavy binders for over 2 years! The idea of using MDF as a base is brilliant, though I haven’t tried it yet. Give it a go! You’ll be surprised how stable it becomes!!! That’s awesome! 🙂
warrenka57
2 Mar 2023 14:17
I think it’s great that so many practical tips are shared here! I’m very familiar with the uncertainty regarding load capacity – you want everything to be securely installed without wobbling or sagging. I also believe it’s important to be very careful when mounting on walls and not to rely too much without verifying. I once had a BILLY shelf that still wobbled slightly despite being wall-mounted because the anchors weren’t ideal. So it’s better to use high-quality anchors.
Regarding reinforcement, I have a question: Are there any experiences on whether the original BILLY shelves tend to warp over time when holding many heavy items, even with reinforcement? Or do they remain stable in the long run?
Nathanaelk
2 Mar 2023 14:55
warrenka57 schrieb:
Are there any experiences on whether the original BILLY shelves warp over time when holding many heavy items?
This is a very important point! The BILLY shelves made of particleboard tend to bend or deform under continuous heavy loads, even when wall-mounted. Reinforcements using metal brackets or additional thin wooden panels can significantly extend the lifespan of the shelves, but they do not always prevent slight sagging after several months of heavy use.
For maximum stability, you can also replace the shelves yourself with plywood panels (at least 18mm (0.7 inches) thick). However, this option is more labor-intensive. If you plan to regularly hold similar heavy loads, such an upgrade is advisable.
A tip: Alternatively, IKEA offers the BILLY Ivar shelving unit, which is made of solid wood and supports much higher weight capacities. It costs more but is better suited for long-term heavy use. Just something to consider as a long-term option.
NOAHSAU
2 Mar 2023 15:16
I think the whole hype around the load capacity of BILLY shelves is a bit exaggerated. Of course, they are not heavy-duty shelves, and their stability is designed for normal everyday use. If you really want to store heavy items, you should buy other shelves specifically designed for heavy loads.
Nathanaelk schrieb:
If you want maximum stability, you can also replace the shelves yourself with plywood (at least 18mm (3/4 inch) thick).
Exactly – or you could do it properly from the start and save yourself the hassle with metal brackets and so on, which means drilling holes and extra costs for furniture that isn’t really made for that. BILLY is meant for books, decorations, and moderate loads, not lead and concrete! 😉
But of course, if you want to try it, go ahead and share your results!
