ᐅ Which BILLY shelves are especially durable for long-term use?
Created on: 24 Sep 2024 10:07
SaufraHello everyone,
I am currently considering getting a BILLY shelf from IKEA, but I have read and heard several times that some versions of these shelves are more durable and better suited for daily use than others. My question is: Based on your experience, which BILLY shelves (for example regarding material thickness, finish, adjustable shelves, or special versions) are particularly long-lasting in use, both in terms of stability and the surface?
I am looking for a model that is as resistant as possible to warping, scratches, or sagging, since I plan to use it frequently and there are children in my home. What variants does IKEA offer in general, and what are your best tips for maximizing the lifespan of a BILLY shelf?
Regarding the durability of BILLY shelves, it is important to first consider the difference in materials: the classic BILLY shelves are mostly made of particleboard with either a melamine finish or a painted surface. The version with a painted finish offers improved resistance to scratches and moisture compared to the purely melamine-coated fronts.
Another important factor is the thickness of the shelves. The standard shelves are 16 mm (0.6 inches) thick, which is sufficient for normal book storage. If you plan to store heavier items, IKEA also offers thicker shelves, or you can use alternative shelves up to 22 mm (0.9 inches) thick, which significantly reduce sagging.
Wall fixings are mandatory for BILLY shelves, as the units tend to tip over, especially when they are taller. These fixings enhance safety and can also reduce wobbling, which helps to protect the shelves mechanically.
The “BILLY/Oxberg” series, for example, features doors with glass fronts that provide better protection against dust, indirectly making long-term maintenance easier.
A general recommendation: if you have children, a surface that is easy to clean and resistant to surface scratches is advisable. Painted finishes are better in this regard than plain foil coatings.
How would you exactly assess the intended use? Is it mainly for books, toys, or general storage?
Dilen schrieb:
How do you assess the specific use case? Is it mainly for books, toys, or general storage?Good question, Dilen! Mainly for books and documents, but also toys and everyday items. Because of the children, I definitely need a durable, sturdy surface, and the shelves should be able to withstand heavy use over time. Stability is the priority; dust protection could be a bonus but is not essential.
I would also like to address the issue of long-term deformation in this discussion.
Particleboard tends to bend over time when subjected to high loads, which can be counteracted by using thicker shelves and installing back panels. IKEA sells additional stabilizers and side panels for BILLY bookcases that allow you to securely place the unit even in corners and recesses.
Regarding surface quality: The version with a foil coating (melamine resin) is relatively resistant to scratches, but if the foil is damaged, the surface tends to fray quickly. Painted surfaces are more uniform and can be sanded or repainted, which is a significant advantage when it comes to repairs.
Using rubber pads under the shelves can also help reduce the resonance of vibrations caused by daily use. This is especially worthwhile if children often play around the shelves.
I am particularly interested in hearing others’ experiences: Do you use painted shelves in everyday life, or the more affordable coated versions? How do they hold up with long-term use?
