ᐅ Which BILLY shelves are best suited for the office?
Created on: 9 Jun 2022 09:37
sartau
sartau
9 Jun 2022 09:37
I want to purchase new shelves for my office and am considering the BILLY series from IKEA. My main question is: Which BILLY shelves are ideal for office use, especially when you need to organize multiple binders, books, and office accessories? I am particularly interested in aspects such as load capacity, flexibility through adjustable shelves, color options that match modern office interiors, and the possibility to expand or combine units. It would also be helpful to know if there are specific versions or variants of the BILLY range that are especially recommended for professional office use. I am looking forward to your experiences and recommendations!
Dirkmin
9 Jun 2022 10:02
Regarding which BILLY shelves are best suited for an office: Generally, the standard shelves measuring 80x28x202 cm (31.5x11x79.5 inches) are very versatile. They offer enough space for binders (standard width 7 cm (2.8 inches)) and can be easily adjusted thanks to the height-adjustable shelves.
For better load capacity, the version with reinforced back panel material is recommended, as it is more stable, especially when storing heavy binders.
The color selection is quite limited, but white and ash veneer are the most common options – white looks more modern and clean, while ash adds warmth to the office.
Extension units work well if more storage space is needed, and door elements can be used for a neater appearance.
Important: For very wide setups, it is advisable to secure the shelves to the wall to ensure stability and safety.
BAUEVA
9 Jun 2022 11:19
I find it a bit too simplistic to just talk about standard shelves without considering the intended use.
What size is your office? Do you need more open shelving for quick access or closed units for confidential documents? The BILLY series is versatile, but not all versions are equally suitable for every situation.
Could you please provide more details on that? How much greater is the load capacity compared to the standard? I assume the maximum load is around 30–40 kg per shelf, which is often a limiting factor for office shelving.
Also, I wonder if the standard height of 202 cm (79.5 inches) might sometimes be too tall for rooms with lower ceilings? Shorter models like 106 cm (42 inches) are also available—perhaps more practical for printers, storage, and similar uses.
chenValeri
9 Jun 2022 12:45
For binders, I recommend shelves with a depth of at least 28 cm (11 inches), preferably 40 cm (16 inches), so that large binders fit easily.
BILLY shelves measuring 80x28x202 cm (31x11x79 inches) are usually sufficient. The 40 cm (16 inches) depth version is less common and more expensive.
White is the most common and neutral color for offices.
kogudra
9 Jun 2022 14:03
To further discuss the suitability of BILLY shelves for an office, I would like to add that besides dimensions and colors, modularity plays a key role.
There is the option to enhance the shelves functionally and visually by using extension units or specially made doors with glass fronts. Glass fronts are particularly advantageous because they allow you to see the contents while preventing dust from entering.
For primarily binder storage, it is advisable to adjust the shelves so that the height matches the binders exactly. This prevents items from slipping and improves efficiency.
Additionally, it should be considered that BILLY shelves are made of particleboard and are therefore less suitable for environments with high humidity; however, they remain stable for normal office air conditions.
rickey
9 Jun 2022 18:51
I can share from personal experience: I bought a white BILLY shelf measuring 80x28x202 cm (31.5x11x79.5 inches) and used it in my home office.
The simple adjustment of the shelves is great, allowing you to store files or books optimally at any time.
Only the stability under full load sometimes felt a bit uncertain to me – that’s why I also installed a wall fixing, which provides security and makes it stand more firmly.
If you need a lot of space for folders, the deeper version with 40 cm (16 inches) depth is really more practical, even though it takes up a bit more room.
Otherwise, the color selection isn’t large, but white usually fits well with any office setup.
