ᐅ Which BILLY shelves are especially sturdy for heavy loads?
Created on: 2 Apr 2017 10:27
U
Urbainman
U
Urbainman
2 Apr 2017 10:27
I am currently reorganizing my workshop and planning to use several BILLY shelves from IKEA for storing heavier tools and materials. I have the question: Which BILLY shelves are especially sturdy when loaded with heavy weight?
I want to avoid the shelves sagging or, in the worst case, collapsing. Are there specific models, materials, or possible reinforcements that should be considered?
It would also be helpful to know if different widths, heights, or special shelves affect the load capacity. Maybe someone has experience with heavily loaded BILLY shelves in similar applications.
Thanks in advance for your insights!
JUANFU
2 Apr 2017 11:02
Urbainman schrieb:
Which BILLY shelves are particularly sturdy when loaded with heavy weight?
It’s great how smartly you’ve organized your workshop! 😊 From my own experience, the classic BILLY shelves in the standard width of 80cm (31.5 inches) are really sturdy, especially when you secure them to the wall.
A useful tip is to reinforce the shelves or use extra-thick boards – that makes a big difference! I once placed heavy toolboxes on them, and the shelves showed no signs of sagging.
I also find the version with glass shelf inserts more stable, as the glass supports often hold more firmly. And very important: always screw the shelves firmly to the wall, otherwise they can tip over. Keep it up, you’re doing great!
fidasi
3 Apr 2017 09:14
JUANFU schrieb:
The classic BILLY shelves in the standard width of 80 cm (31.5 inches) are really sturdy, especially when you attach them to the wall.
I would like to explain in more detail how the stability of the BILLY shelves is achieved and what to consider specifically when dealing with heavy loads.
The standard BILLY shelves are made from particleboard or fiberboard coated with melamine foil. This construction contributes to a certain level of stability; however, the load capacity of each individual shelf panel is limited to about 15 kg (33 lbs) when the weight is evenly distributed.
For heavy loads, it is definitely advisable to consider the following points:
1. Wall mounting: Without it, there is a high risk of tipping. The taller the shelf and heavier the load, the more essential this becomes.
2. Shelf reinforcement: IKEA offers specific metal reinforcements, and you can also install your own metal or wooden support strips under the shelves.
3. Shelf depth and width: Deeper shelves of 40 cm (16 inches) provide more stability than narrower ones; tall shelves with multiple shelves distribute weight better, but the weight per board must be limited.
4. Center of gravity: Store heavy items as low as possible to reduce pressure on lower shelves and the tipping moment.
5. Alternative models: The BILLY series also includes versions with sliding or glass doors, which can provide additional bracing.
I’m interested to know exactly what tools and materials you plan to store and how often the shelves will be moved or repositioned, as this also affects stability requirements. I’m happy to provide reinforcement tips with technical advice if needed.
Issac_kla2
4 Apr 2017 13:37
fidasi schrieb:
The standard BILLY shelves are made of particleboard or fiberboard panels coated with melamine foil.
Yes, that’s exactly the point for me! These shelves are not designed for heavy loads, but rather for household use with books and decorative items.
I think it’s almost a myth that BILLY shelves are particularly sturdy – they only hold up if you screw them to the wall, and even then the weight capacity is limited. In my opinion, anyone who really wants to store heavy loads should either choose solid metal shelving or, for so-called “heavy-duty shelves,” consider IKEA’s Hejne system, for example.
Of course, you can increase the load capacity with certain tricks, but then you are no longer talking about a standard BILLY shelf.
Also, I wonder if it’s not rather dangerous to overload these shelves and rely on the hope that they will remain stable. Safety should always come first!
