I recently bought several Billy bookcases from Ikea to better organize my home office. Since I plan to use the bookcases for many years and to store some heavier books, I’m especially interested in the question: Which Billy bookcases are generally the most durable? I’m not only referring to their stability and sturdiness but also to the resilience of the materials, optimal load capacity, and any differences between various versions (for example, in depth, width, material thickness, or surface treatment).
At first glance at the range, I noticed there are different options—such as with or without a back panel, glass or wooden doors, various colors, and finishes. I’ve also heard that some models work better with reinforcements. I would really appreciate any experience reports or assessments about how durable the different models are for long-term use.
Thanks for your support! Are there any tips regarding assembly or installation that could help maximize the lifespan of a Billy bookcase?
pilous schrieb:
I wonder if the statement "Back panel makes the shelf the most durable" is really valid in such a general wayThis is an important point. While the back panel does increase the shelf’s torsional stiffness, which is helpful for taller shelves, it does not replace the load-bearing capacity of the actual shelves.
From my experience and various tests I have studied, a main issue is that the shelves tend to sag over time under higher loads, especially with wider shelves.
A more effective measure than just a back panel is to install additional support strips beneath the shelves.
There are modified solutions with metal braces available that can be used as an addition; these are a long-term sensible option when planning for heavy loads.
chenValeri23 Apr 2020 14:42Regarding durability: The most common weak point is the shelves, especially when overloaded with heavy books.
The optimal solution is to use the standard width of 80cm (31.5 inches) while adhering to the official load limits. Also, do not skip the rear wall mounting.
For wider shelves, it is better to consider additional reinforcements or choose narrower models.
RonJarrett23 Apr 2020 16:03A load capacity test shows that the standard Billy shelves do not suffer permanent damage when loaded with a maximum of 30 kg (66 lbs) per shelf.
I agree with this. Professional office furniture often uses extra reinforcements, which can also be added to Billy shelves.
It is also important to note that the shelves can swell significantly when exposed to moisture, weakening the structure. Therefore, shelves should be placed in as dry conditions as possible.
karus66 schrieb:
A more effective measure than just a back panel is to install additional support strips under the shelves.
karus66 schrieb:
A more effective measure than just the back panel is to install additional support strips under the shelves.Exactly! I have reinforced shelves with metal strips before, and it really makes a huge difference in preventing sagging. This is especially a great tip when you have a large number of books.
I also admit that I’m a fan of regularly checking the shelf and avoiding loading it with unnecessarily heavy items.
And 🙂, always make sure to install and secure it properly to the wall—that simply adds safety.
edisondan schrieb:
The 80x28x202 cm (31.5x11x79.5 inches) model with a back panel is generally considered the most load-bearingThanks for all the insightful answers so far! I’m much better informed now.
One last question: From your experience, are there any significant differences between the Billy shelves in white or beech regarding durability? Some say beech feels more robust, others say it’s purely cosmetic.
What about the material quality? Or do the surface finishes noticeably affect the longevity?
I hope someone here has a solid assessment, as I’m still undecided about which to choose.
