ᐅ Which BILLY shelves are better suited for heavy loads?
Created on: 25 Sep 2024 08:24
Achim50
I am planning to use several IKEA Billy bookcases in my hobby room to store quite heavy items such as several heavy binders and some tools. However, I am unsure which versions of the Billy bookcases are best suited for this purpose.
I understand that there are different models of the Billy, for example with classic wood-based panels, metal reinforcements, or different types of shelves. My specific question is: which Billy bookcases or features are best for safely supporting heavy loads over time without the shelves sagging or the unit becoming unstable?
I would appreciate any experiences, practical advice, and possibly tips on upgrades or alternative products within the Billy range, as the bookcase needs to fit well aesthetically in the room but also be secure and load-bearing.
Thanks in advance for your support!
sanjon
27 Sep 2024 08:29
40 cm (16 inches) shelves are better for heavy loads. They sag less.
Angle braces on each shelf are a must for loads over 20 kg (44 lbs) per shelf.
GiRoyce
27 Sep 2024 09:52
Just a quick note on load distribution: When placing heavy boxes, try to store the heavier items at the bottom and the lighter ones higher up.
This lowers the center of gravity and increases stability.
Even if you reinforce the shelves, avoid point loads at the edges, as these weaken the shelf boards the most.
Achim50
27 Sep 2024 12:16
Great tips, thanks!
So, I’m focusing on 40cm (16 inches) wide shelves, using metal insert shelves plus angle reinforcements. The shelf will be fixed to the wall, preferably with double fastening for large shelves.
I will also pay attention to the stacking height to keep the center of gravity low.
If there’s anything else I absolutely need to consider during assembly, please let me know.
