I am planning to use several IKEA Billy bookcases in my hobby room to store quite heavy items such as several heavy binders and some tools. However, I am unsure which versions of the Billy bookcases are best suited for this purpose.
I understand that there are different models of the Billy, for example with classic wood-based panels, metal reinforcements, or different types of shelves. My specific question is: which Billy bookcases or features are best for safely supporting heavy loads over time without the shelves sagging or the unit becoming unstable?
I would appreciate any experiences, practical advice, and possibly tips on upgrades or alternative products within the Billy range, as the bookcase needs to fit well aesthetically in the room but also be secure and load-bearing.
Thanks in advance for your support!
KAULIS schrieb:
Metal shelves are significantly more load-bearing; they can realistically support up to 30 kg (66 lbs) per shelf.I can only agree with that. I have two Billy bookcases where I installed metal shelves. They feel much more robust and really hold up well.
However, you should make sure the shelves snap in properly and don’t have any play.
Also, if you store heavy tools, I would recommend distributing the weight across multiple shelves, not just one.
lyndon schrieb:
Adding extra metal brackets to reinforce the shelves can also be a good idea.I did that too, especially for heavy loads it’s a very sensible step.
The standard BILLY shelf is not ideal for heavy loads, even with metal shelves.
So, if you need to store very heavy items weighing more than 30 kg (66 lbs), you will need an alternative. Metal shelving or heavy-duty shelving is more suitable in that case.
BILLY is primarily designed for books and light storage items.
Thanks in advance for the many helpful answers!
To add some details: The weight per shelf will be approximately between 20 and 35 kg (44 and 77 lbs), distributed across boxes and binders. I can choose the spacing between the shelves flexibly.
So if I use metal shelves and additionally reinforce them with brackets, that should generally be sufficient. The idea of having multiple units is good, so I don’t load everything all at once.
Are there differences between the BILLY versions, for example in color options or widths (40 and 80 cm (16 and 32 inches))? Does an 80 cm (32 inches) shelf possibly hold more than the 40 cm (16 inches) one? Or is that rather irrelevant for the load capacity?
Achim50 schrieb:
Are there differences between the BILLY versions, like the color options or the widths (40 and 80 cm)?The color and surface finish usually do not affect the load capacity. However, the width is indeed important: An 80 cm (31.5 inches) wide BILLY shelf has longer shelves that can bend significantly more than the 40 cm (15.7 inches) wide shelves.
The 40 cm (15.7 inches) shelves are generally more stable for heavy loads because the leverage and deflection of the shelves are lower.
Achim50 schrieb:
Or is that rather irrelevant for the load capacity?It is definitely relevant – for very heavy loads, if space allows, I would prefer several narrow shelves instead of a few wide ones.
lyndon schrieb:
The color scheme and surface finish generally have no impact on the load-bearing capacity.That is correct. Another point regarding stability: For BILLY shelves with glass doors or additional shelves, the overall weight can increase due to the doors and fittings. If you plan to carry heavy loads, you should remove the doors or choose models without doors to reduce tipping moments.
Additionally, different wall mounting options can be combined. For large shelves, a double wall mount is recommended to enhance stability.
