ᐅ Which BILLY models are especially sturdy and durable?
Created on: 17 May 2023 08:14
Jacques
I am currently looking more closely into IKEA furniture, specifically the BILLY bookcase series. Since I am searching for particularly sturdy and durable models that can withstand heavy daily use, I wanted to ask in this forum which BILLY models you consider to be especially resilient.
I am interested in both the use of different materials, such as solid wood or particleboard, as well as the design and construction of the shelves. Perhaps someone has long-term experience or comparisons between the variants (e.g., depth, width, versions with or without glass doors).
I am also looking for tips on optimal care and possible reinforcements that could extend their longevity.
So, which BILLY models are especially robust and durable? Thanks in advance for your opinions and experiences!
Fitigu
17 May 2023 11:30
For the durability of the Billy shelves, the following technical details should be considered:
1. Material: The BILLY series primarily uses particle boards with a melamine coating, which provides good surface hardness but does not offer high load-bearing capacity under heavy stress.
2. Dimensions: Models with smaller widths (40 cm (16 inches)) are more stable due to lower leverage effects, especially without wall mounting.
3. Doors: The door frames, especially on glass doors, significantly increase the structural stiffness.
4. Mounting: Without wall installation, the allowable load decreases significantly. Proper screwing is technically recommended.
For areas with high load requirements, modular combinations are advisable instead of using single large shelves.
toril
17 May 2023 12:05
I will add a technical perspective:
The BILLY shelves have a back panel made of thin hardboard, which reinforces the frame structure but only distributes load to a limited extent. In shelves intended to carry particularly heavy weight, such as books or heavy objects, the load capacity of the standard units is limited by the middle shelves.
The 28 cm (11 inches) depth is a good compromise between stability and usable space – the 40 cm (16 inches) wide models are more stable due to their narrower width, even though they offer slightly less storage capacity.
For reinforcement, some models can be equipped with additional metal brackets or support rails, which IKEA partly offers as accessories.
Without wall mounting, a clamping system combined with a door frame can be an alternative, although it does not resolve all structural issues.
Jacques
18 May 2023 07:22
nedagla schrieb:
I have been using the BILLY 40x28x202 cm (16x11x79 inches) with glass doors for 6 years, and it’s holding up great! 🙂
Hello, thanks for sharing your experience; that helps me a lot. I’m still curious about how you use the shelves, as I also have some heavier books. Do you use the original shelves, or have you reinforced them somehow?
toril schrieb:
For reinforcement, some models allow additional metal brackets or support strips, which IKEA sometimes offers as accessories.
Could you possibly give an example of how such support strips can be effectively installed in the BILLY? I’m a craftsman, so I can make some adjustments myself, but I don’t want to ruin the appearance.
Jensson
18 May 2023 07:55
Hello Jacques,
I’d like to provide you with a brief guide on how to improve the stability of the shelves in BILLY:
1. Identify the shelves that bear the most weight.
2. Purchase suitable metal brackets (20x20 mm or 30x30 mm) at a local hardware store or online.
3. Attach 2-3 brackets underneath each shelf, drilling small pilot holes to prevent the wood from splitting.
4. Make sure the brackets are fixed on the inside at the back or on the side of the shelf unit so they remain visually unobtrusive.
5. Optionally, you can also install a thin strip (e.g., pine wood, 12x12 mm) under the shelves as a support to further increase load capacity.
In summary: Using metal brackets is a proven method to reinforce the shelves without significantly affecting the appearance.
If you want a more detailed guide, I’d be happy to prepare one.
Jacques
18 May 2023 08:10
Jensson schrieb:
Using metal brackets is a proven method to provide additional support for the shelves without significantly affecting the appearance.
Thank you very much, that sounds like a practical solution. I would be very grateful if you could also provide a detailed guide! I see BILLY as a good basic piece of furniture that can become very durable with some small improvements.
Jesus9
18 May 2023 09:05
I find the discussion here very valuable! I feel the same way as Jacques – I have a BILLY shelf that I use every day, and at some point, you start worrying about its durability, especially when family members or daily work use put a lot of strain on the furniture.
It reassures me a lot that there are many practical tips, especially about securing and reinforcing the shelves. This shows me that investing in BILLY can definitely pay off in the long run.
BILLY is actually a series that is affordable and flexible, but with tips like these, it gains more "heart" and becomes a true companion. Thanks to everyone who shares their knowledge so thoroughly!
