ᐅ Which Bilily shelving units are especially popular due to their sturdiness?
Created on: 7 Dec 2023 08:23
Yonasno
Yonasno
7 Dec 2023 08:23
I am planning to buy several Billy shelves from Ikea and I am especially focused on their stability. Since there are different versions and accessories available, I would like to know which Billy shelves or variants are particularly popular with you when it comes to strong steadiness and load capacity.
Are there specific models or practical tips (for example reinforcements, certain materials, or fastenings) that make the shelf especially sturdy? I look forward to your expert feedback and personal experiences!
Timofa
7 Dec 2023 08:47
Hey Yonasno,
Of course, you want the Billy shelf not to fall apart under the first load, right? 😊 I personally always go for the classic white frame shelves—they’re sturdy enough to hold even heavier books.
What really helps are the original Ikea backing panels made of particleboard, which give the shelf solid support. If you want it even more stable, be sure to fix the shelves to the wall—that makes a huge difference!
And if you like the truly heavy-duty look, the extra metal fixing kit from Ikea also reinforces the structure very well.
Cecilera66
7 Dec 2023 09:12
I recommend the Billy shelf unit with the 80cm (31.5 inches) wide shelves. They are more stable than the narrower ones. Don’t forget wall mounting.
Jensson
7 Dec 2023 10:03
Hello Yonasno,
to improve the stability of the Billy shelves, there are several points to consider:
1. Model choice: Wider versions (80 cm (32 inches)) are more stable than narrow ones (40 cm (16 inches)).
2. Material: All Billy shelves are generally made from laminated wood, so stability mainly depends on correct assembly.
3. Back panel: A solid back panel made of particle board is essential to keep the frame stable.
4. Wall attachment: This is mandatory! Without securing the shelf to the wall, it can easily tip over.
5. Additional components: For extra stability, there are metal brackets and reinforcements from Ikea that can be attached between the shelves and side panels.
My advice: If you plan to fill the shelf with heavy books or decorations, use the 80 cm (32 inches) wide Billy, secure it to the wall, and add reinforcements. This will also help prevent the shelves from bowing.
Mufato
7 Dec 2023 10:18
The key to the Billy shelf is proper wall mounting and the back panel. Otherwise, the shelves may wobble easily.
nonpra
7 Dec 2023 10:38
The 80cm (31.5 inches) version with additional wall mounting is the most stable. Avoid free-standing installation without wall anchoring.
