Hello everyone, I recently bought an IKEA Brimnes bed and am now about to assemble it. I want to work as efficiently and error-free as possible since I don’t want to have to take everything apart again. What assembly tips are especially helpful for the IKEA Brimnes? I’m mainly looking for practical advice on preparation, the order of assembly, and common pitfalls. I’m also interested to know if there are any special tools that make assembly easier or if the included tools are sufficient. I look forward to your experiences and instructions!
For preparation, I recommend first reading the entire manual and cross-checking all parts with the parts list. It is important with Brimnes to set up the side panels perfectly straight before attaching the crossbars. Otherwise, everything warped for me. Also, use a rubber mallet instead of a regular hammer to protect the surface. And take your time – rushing easily leads to mistakes.
A structured approach significantly simplifies the assembly. Here is my step-by-step tip:
- First, check all parts and lay them out in an organized manner.
- Use the included Allen key, but keep a cordless drill ready to screw faster, using only low torque.
- Start with the side panels, then the slatted frames, and finally the headboard and footboard.
- Pay special attention to ensure that the wooden dowels and screw connections are properly seated and not over-tightened, as this can damage the material.
- After each step, check the squareness using a square or ruler.
If possible, ask a second person to help hold the parts – this will save frustration.
Common mistakes:
- Fully tightening all screws at the very beginning
- Assembling parts twisted or misaligned
- Neglecting to check the alignment
With some patience, you’ll succeed. Good luck!
Common mistakes:
I often wonder if all the effort with a cordless drill and aiming for perfection is really necessary for a piece of furniture that often doesn’t last for decades. IKEA furniture is designed for simple assembly, so overdoing it sometimes causes more stress than it helps. But well, to each their own...
