ᐅ Which assembly steps help prevent injuries when building the IKEA Metod kitchen system?
Created on: 5 Apr 2023 10:23
diar43Hello everyone,
I am currently planning to assemble an IKEA Metod kitchen cabinet and want to avoid injuring myself during the assembly process. Therefore, I am interested in which specific assembly steps or methods can significantly reduce the risk of injuries while building.
Are there practical tips, safety measures, handling techniques, or particular sequences that have proven to be especially safe? I am not only referring to tool use but also to lifting heavy parts, stabilizing components during assembly, or avoiding mistakes that could lead to sudden hazards.
I would appreciate it if you could share your experiences with me, including professional insights or personal incidents where safer procedures helped you avoid accidents. Thanks in advance.
Hello diar43,
Your question is very well formulated and important, because when assembling furniture like IKEA Metod, attention can quickly wane, which may lead to accidents.
Specifically, it helps to prepare your workspace well before starting: clear surfaces without trip hazards and good lighting. I also recommend laying out and sorting all parts beforehand. This avoids frantic searching and gives you better control over the parts, which helps prevent injuries.
During assembly, heavy parts should ideally be lifted or stabilized by two people. Try to use techniques such as bending your knees rather than your back when lifting, as this protects against back injuries.
Tools: Use the right tools to prevent screws from slipping or breaking. For example, screwdrivers with ergonomic handles can be very helpful.
One more important point: take breaks, especially if the assembly takes longer. Fatigue can reduce concentration and thus increase the risk of injury.
I hope this helps you and others here!
I would like to add that there is a clear sequence effect when assembling the IKEA Metod kitchen units, which also helps prevent injuries.
1. Preparation: Before starting assembly, sort all screws, dowels, and screwdrivers by type and size. This prevents distractions or searching for spare parts while screwing – reducing stress and mistakes.
2. Assemble frames and side panels first: These parts should be assembled lying flat. This helps avoid heavy or bulky parts falling or getting tangled.
3. Using clamps or screw clamps to stabilize larger units is helpful, keeping your hands free and reducing strain on your arms.
4. When attaching shelves or doors, never hold the parts freely in the air; always support them with a helper or on a stable surface – this significantly reduces the risk of unexpected slips.
5. Work height is an important factor not to underestimate. Ideally, place your units on a tabletop or sawhorses – this protects your back and helps prevent injuries from bending or overreaching.
6. Finally, check that all screws are firmly tightened. It’s better to gently tighten screws a bit more than to force them aggressively – this prevents slipping tools and injuries.
If a hammer is needed: never strike blindly; always use a steady hand to avoid slipping blows or injuries.
In summary: proper preparation, following the assembly sequence, and working ergonomically are key to a safe assembly process.
sarlo schrieb:
When assembling, you should ideally lift and stabilize the heavy parts with a partner.I completely agree with that. I was really worried about straining my back during my first Metod assembly. Especially the large side panels are difficult to handle alone.
I also want to add: nervousness and stress during assembly increase the risk of accidents. Always breathe calmly, take short breaks, and don’t rush yourself. Even if you have a goal – safety comes first.
Additionally, just before assembling, I always checked all screws and drill holes to avoid accidentally hurting my fingers later due to loose screws falling out.
I’m curious if anyone has experience using gloves or other protective equipment during this type of furniture assembly?
Layla schrieb:
I’m curious if anyone has experience using gloves or other protective equipment during furniture assembly?Yes, gloves are usually a good idea, especially when working with untreated wood edges or handling metal fittings. They protect against splinters and minor cuts. However, make sure the gloves aren’t too thick, as that can reduce your sense of touch when screwing or inserting dowels.
Safety glasses are also a good idea when drilling, even if you’re not using a cordless drill, in case pre-drilling holes is necessary.
Overall, it’s best to adjust protective equipment depending on the task and not necessarily wear everything all at once.
