ᐅ Which assembly steps for IKEA BRIMNES should not be skipped?
Created on: 21 May 2022 18:37
ren38
ren38
21 May 2022 18:37
I have just started assembling my IKEA Brimnes furniture and noticed that some assembly steps are quite time-consuming. This raises a basic question for me: Which assembly steps for the IKEA BRIMNES should absolutely never be skipped or shortened, even if they might seem a bit complicated or unnecessary at first glance?
I understand that every piece of furniture comes with detailed instructions, but I especially want to know if there are critical steps that are essential for the stability, safety, and durability of the furniture.
Does anyone have experience with which parts should be carefully checked to ensure they are assembled correctly? Are there any common pitfalls where it is advisable to invest extra time?
I look forward to your detailed insights and tips!
sarlo
21 May 2022 20:05
Hello ren38,
Your concern is very valid, especially for furniture like the BRIMNES, which consists of multiple parts and needs to provide both stability and functionality. It is important not to skip any steps without careful consideration.
From my experience, you should particularly avoid rushing or skipping the following assembly steps:
- Carefully aligning and securing the back panel: This is crucial for the overall stability of the furniture. If it is not properly fixed, the piece may wobble or, in the worst case, lose its shape.
- Precisely positioning and correctly installing the connecting elements (e.g., dowels and screws), as they distribute the load. Being careless here risks reducing the furniture’s durability.
- Attaching the safety brackets, especially if the furniture is tall. These prevent tipping and are very important, particularly in households with children.
Additionally, it is helpful to read the instructions step by step promptly and check the parts in advance to avoid unpleasant surprises during assembly. This can sometimes prevent costly mistakes.
If you need more detailed explanations for any of the steps, feel free to ask!
sifope
22 May 2022 09:48
sarlo schrieb:
Careful alignment and securing of the back panel: it plays a major role in the stability of the entire piece of furniture.
Exactly, I fully agree with that. It’s often the case that, especially with BRIMNES, the instructions are seen as too shallow overall, but the back panel is definitely not an area where skipping steps or shortcuts can be made.
If you work half-heartedly there, you risk twisting and eventually damaging the fittings.
A common issue I see is insufficient checking of screws and dowels before the final tightening. You should verify the fit of the parts and if anything is unclear, it’s better to go back a step.
It’s also interesting that some people report neglecting the attachment of the bottom panel because they think the furniture will hold without it. However, my experience and other reviews show that this step is crucial for load-bearing capacity.
So my advice: be sure to follow all fixing and connecting instructions thoroughly, even if they seem repetitive or fiddly! Saving time is not saving on quality or safety.
fepau
22 May 2022 12:16
Hello everyone!
What a great discussion here – I can highly recommend one thing: Don’t skip any steps! 😊 Especially with the BRIMNES products.
I clearly remember that when I first assembled it, I was too rushed and only did the step with the back panel “temporarily” for the sake of time – the furniture was very wobbly then. The second time, I followed every step carefully, making sure everything fit perfectly, and as a result, the furniture stands rock solid!
One more tip: Take the time to read through the entire instruction manual beforehand. This saves a lot of frustration later on. And if possible, don’t assemble alone but with two people – it makes handling much easier, especially for the larger parts!
So really: Patience pays off big time, particularly with almost every step!
Good luck to everyone who is assembling right now! 💪
nubar
23 May 2022 08:57
From my perspective, there are several key points that should not be overlooked when assembling the IKEA BRIMNES:
- Securing the back panel: The back panel stabilizes the furniture laterally and prevents it from leaning or warping. Poor installation can lead to instability and mechanical stress.
- Tightening the fasteners in the correct order: Do not fully tighten the screws right away; instead, first loosely assemble all connections, then tighten them all afterwards. This helps avoid misalignment or tension in the material.
- Installing the wall attachment: Even if the furniture seems stable at first, the wall fixing should be installed if it is provided. This is especially important for tall furniture as a safety measure.
- Checking the leveling screws or adjustable feet to prevent the furniture from tipping on uneven floors.
In general: it can be tempting to skip steps, but these small precautions ensure long-term stability.
Feel free to ask if you need details on any step.
