ᐅ What are the important installation steps for fitting Ikea Metod kickboards?
Created on: 5 Nov 2020 18:37
sazan
sazan
5 Nov 2020 18:37
I am about to install the kickboards for the Ikea Metod kitchen system and have a few specific questions about the installation steps. Since the kickboards ensure a clean finish along the floor, it is important for me to get this right from the start in order to avoid future issues.
What installation steps are important when fitting Ikea Metod kickboards to ensure they are stable, accurately fitted, and visually appealing?
I am particularly interested in recommendations for surface preparation, attaching the kickboards to the cabinets or the wall, and tips for handling corners and transitions between individual boards.
Are there common mistakes I should avoid? And do I need any special tools ready?
I look forward to your experiences and helpful advice!
Pome60
5 Nov 2020 20:41
Hey sazan, great question! 😃 I just installed my Metod baseboards last week and can share some tips to make sure it turns out really well!
First of all: Preparation is key! Before attaching the baseboards, make sure everything is level. Especially with Metod cabinets, the floor can vary a lot, so adjust the feet carefully.
Then follow these steps:
- The baseboards are first attached to the cabinets using the special clips that Ikea provides. Place the clips evenly to ensure the baseboards hold firmly later on.
- For the corners: cut the baseboards at a 45-degree angle for clean joints and a polished look.
- Make sure not to press the baseboards too tightly against the wall; leaving a small gap for expansion is important.
You will definitely need a miter saw or a metal saw, a cordless drill, a spirit level, and ideally a hammer for the clips.
And don’t worry if it seems complicated at first: with patience and a bit of fun, it’s totally doable! Good luck! 🍀
PRA64
6 Nov 2020 08:23
Pome60 schrieb:
You definitely need a miter saw or a metal saw, a cordless drill, a spirit level, and preferably a hammer for the clips.
Good overview! I’d like to add a few points and present the process a bit more systematically.
Important installation steps for Ikea Metod kickboards:
- First, properly level all cabinet feet to ensure the kickboards sit flush.
- Measure the kickboard lengths precisely and cut them with a miter saw if necessary (especially at the corners).
- Attach the clips to the cabinets. They should be spaced to provide firm support yet allow the boards to snap in easily.
- Snap the kickboards in piece by piece and gently tap them with a rubber mallet to ensure they fit snugly.
- For long runs, watch out for any required expansion joints—kickboards should not be forced under tension.
- Check if the kickboards need additional fixing to the wall in some spots to prevent wobbling.
A common mistake is skipping the leveling of the cabinet feet, causing the boards not to sit properly. Also, rough cuts without mitering at the corners result in unsightly gaps.
If you take your time, work step by step, and regularly check your progress, the final result will be very satisfying.
Good luck!
pilous
6 Nov 2020 09:15
PRA64 schrieb:
A common mistake is skipping the leveling of the feet, which causes the baseboards not to sit properly later on.
Here, I need to add a critical note: Most recommendations emphasize the importance of leveling the feet, but the connection to varying floor conditions is often overlooked. Especially on uneven floors, even well-adjusted feet cannot compensate for all irregularities.
Therefore, before installation, I strongly suggest carefully inspecting the floor and, if necessary, placing small shims under the cabinet feet. This ensures a stable foundation and prevents later warping of the baseboard.
Pome60 schrieb:
For the corners: cut the baseboards at a 45-degree angle to create clean joints and a polished look.
Generally yes, but be cautious with room layouts that do not have right angles. In such cases, a 45-degree cut is not sufficient, and precise angle measurements are needed to achieve perfectly fitting joints—ideally using an angle finder or a bevel gauge.
Overall, I recommend not simply following standard patterns but first thoroughly assessing the specific conditions on site and then planning accordingly.
Baseboards may seem like a small detail, but it is often where the quality of a kitchen installation truly shows.
Josan
7 Nov 2020 07:57
pilous schrieb:
Here I need to make a critical comment: Most advice emphasizes the importance of floor leveling, but isn’t the connection with different floor types often overlooked here?
That’s an excellent point. I’d like to add that with Ikea Metod baseboards, the clips can be attached not only to the cabinet but sometimes also to the wall using small brackets to provide more stability – especially on uneven floors.
One more thing: Before you install the baseboards, definitely do a dry fit! Lay the boards out to see how they fit together and to check that no stress or tension occurs.
And if possible, use the original Ikea parts for installation, since replacement products can sometimes cause issues with fit.
Don’t worry, with careful planning and these steps you’ll achieve a nice result. If you’d like, I can also share tips on working with corners, especially if you don’t have a special tool available.
